Since this has come back up, I thought I would add something that gets left out of such threads:
Casting brass, aluminum, nickel, etc. requires good fume extraction and a thought for safety. The fumes from melted metals can sometimes be deadly....especially when melting scrap. Just remember that if there is lots of slag, there is lots of stuff that isn't the metal being melted. Melting brass is the most likely to have hazardous fumes. Smelting in a closed shop.....no matter how big, is a bad idea.
"Good Extraction" isn't just a fan and an open window. It is a dedicated vent hood and fresh air replacement system. Also, depending on where you live, the fumes vented outside your shop may be under regulations.
Just a note, if planning on making objects for turning and ones that will be finished, a flux is required to clean off the dross and cover the melt from oxidation. Without a flux you will be casting in a lot of oxides and crud. Merely scraping will not stop the oxidation, as it just exposes fresh metal to the air. Best to use a flux without fluoride in your setup. Plain borax works fine, or use a mix of anhydrous borax and boric acid. Commercial low-sodium/low-fluoride flux is great, but for your home casting setup, probably not necessary. The flux will not only make the metal cast cleaner, it will make it flow better into the molds. Scrape the dross one last time and toss in a teaspoon of borax and the surface will be like a mirror when you pour.
