If you could design a variation of any one Spydie....
"Lum Chinese with blue G-10 scales"
second on that!!!
but about 1/5 larger and a black Temperance skeleton clip.
M
Lum Chinese, but with Ivory Micarta scales!! (although any micarta would be nice) and rounded like the customs
Shabaria with 5" blade. VG10 is fine. Maybe G10 handle. The way it was originally designed. :) Also tip up carry. Just a sprint run. A few hundred. :)
Blades
Start with a Rescue Jr. Make the blade 2 7/8", so that it is legal in places that require sub 3" blades. Use VG-10, and add a little bit of plain edge at the tip, for maximum utility. Then bring back the stainless steel handle, but add Kraton inserts like the ProGrip II. Perfect!
I don't ask for much, do I? Just a tweak here and there...;)
I would love to see a Olive Drab G-10 Pro Grip with VG-10... Nice rugged little outdoor knife...
Originally posted by Jazzman
I would like either:
- a smaller (2.5in), framelock Lum Chinese
- a Folding SPOT
- a Folding Ronin
- plainedge ladybug
- framelock Cricket (looks like I'm going to get one!)
Matt
There is a folding Ronin - the Yojimbo.
There is a framelock Cricket - the SS model.
There is a folding SPOT - to be released ;)
BTW, I think you may say there is a PE Ladybug too - the Mosquito model was a Ladybug originally :)
I would love a C01 Worker with S30V blade, compression lock, G-10 scales (CF or even FRN welcome), finger choil (a la Calypso jr.), tip up/down left/right carry ;)
Larger bladed Gunting, with fully serrated blade, and a more pronounced "skull-cracker" tail like the Dodo. Perhaps with a fixed carbide tip.
The temperance fixed blade with the same shaped handle but kraton inserts to make it stickier. The present handle is a touch slippery.
Spyderco Military
-VG-10 or S30V.
-Tip up/Tip down carry
-Left or Right handed carry
-Frame or Compression lock
Realistic wishes
Lil' Temperance in BG-42, Rc 60+, handles maybe some other color, or titan with integral compression lock (only if it were as strong as a present compression lock).
Native FRN, in S30V, but with two liners, thickness like Wegner Jr. 's liner. Bring the lock as far as possible to the MBC rating, maybe by increasing the blade thickness to 3.5 mm. Would be a lighter and cheaper alternative to the Lil'Temperance, a pefect SD Lil' fighter.
Special addition of Delica with BG-42 and CF. Would be a terrific combo with a present Lil' Temperance.
Not so realistic wishes
Wegner Jr. in BG-42 or S30V, both with Rc 60+, maybe with a second liner added (because of symmetry). As a Forum knife, or whatever addition.
Wishful thinking?
Fixed blade Native, the same as FRN but fixed blade. Maybe somewhat thicker - 3.5 mm, S30V.
Perrin's bowie with a full tang.
Spyderco Suvival Knife in the category of the Fallkniven A-1.
Franco
ti-liner, aus-8, SE, G-10 scales, compression lock endura
Edited to add: old, pointy-butt shape, and 3 screw clip.
Further edited to add: serrations ground on other side..
1) The return of the Wegner
2) Lum Chinese w/ textured G-10/Micarta
3) Gunting w/ 3 3/4" or 3 7/8" blade
4) Paramilitary (when & where?)
How about a Native that's fully flat ground, as opposed to the sabre/hollow grind that it comes in now. I've flat ground my FRN/440V Native, and it works better like that.
Marty123,
Any pictures available on your flat grind. It'd be very curious what it looks like on the native.
Chris
