Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
I don't know if you've seen this video I put out. My Magnacut is pretty good but my Delta 3V is bananas.
We had this pre-order for this DEK3 in both 3V and Magnacut.
We normally get some losses in any project but we're looking at a very high scrap rate for these due to a cosmetic issue that developed with the steel after heat treat. So much so, that there will be none available in Friday sales and we will be stretched just fulfilling the pre-order.
We have enough normal work to meet about half of the pre-order. We have enough good but not perfect work that we can probably correct some minor cosmetic issues by hand grinding them and meet the rest of our orders. However, it is not impossible that I may end up rejecting enough of these that we may end up needing to issue a few refunds.
So, with that said, if you have a Magnacut DEK3 on pre-order and you want to keep your order as it is, that's probably not going to be a problem. You don't need to do anything and we will attempt to fill your order as originally planned.
But, if you happen to have Magnacut DEK3 on order and you want to change it to Delta 3V, please let Jo know and we will change your order for you.
Thanks,
Nathan
Thanks,
Nathan
