- Mar 15, 2000
A while back, I cut a feeding port into this IKEA utensil caddy. Not a novel idea by any means, but I wanted to build my own IKEA kit.
I wound up going with one of the Stanley Cooksets and a Walmart stainless mug. All told, the kit cost right around $30.
I had the aluminum rod laying around, and I cut and bent it to size for the pot rack.
Nested.
I took advantage of the first burn to break-in a couple of Beckers. One is a BK-9 I'd intended to sell, but because it's the thicker Camillus version, I never could quite part with it. I put some Ka-Bar micarta on it, and it is a dandy. The other is a BK-2 I won in the raffle down at Ethan's last Gathering. I used both knives, plus my trusty 16, for some wood prep.
Here's the stove loaded for ignition. There's a little bit of fatwood "kicker" mixed in there.
Time to get it on.
The pot blackened up nicely.
Got a little bit of boil going.
Final flames.
And a cup of joe.
Some thoughts:
Nested.
Time to get it on.
Final flames.
And a cup of joe.
Some thoughts:
- Overall, I like the way the hobo stove worked. I thought I might want to enlarge the feeding port, but it functioned fine just like it was.
- I also liked the fact that the Stanley pot allowed enough room on the edges to feed the fire from the top without removing the pot.
- I might work on some way to get the stove off the ground to prevent heat conduction on cold surfaces.
- I'm considering a staking system to keep the stove more stable.
- As far as the pot supports, I thought about tapping the rod ends for a nut so that (a) they're still removable, but (b) there's less chance of them slipping.
- I also may make a cross-style support with some aluminum stock to fit on the top of the stove.
