Reverend Pete,Originally posted by Rev. Pete
Thank you to all the contributors on this thread for taking the time to share your sharpening techniques. For each of you my question is "where did you get your strop and stropping compound". I know this has been asked and answered before, but please humour me.
I start off with a piece of undyed tooling grade leather, about belly hide weight. It can be got at a Tandy leather and craft supply or saddle shop or boot/shoe maker or saddle shop, it depends on where you live.
Cut a piece about 18 inches long by 1-1/2 -3 inches wide, depending on the size knives you will be sharpening. You don't want the leather to be too much wider than the knives you'll be stropping or the tip will hang up so it's safer to go slimmer than wider, also a 1-1/2 -2 or 3 inch strop gives you plenty of room to maneuver without having to work too hard on controlling your angles.
The compound I have always used is a jewelers grade called White diamond but Fulloflead got his at a Sears where the buffing compounds are located, they come in several different colors. The color signifies the grit, red being strictly rouge for finish polishing only and the white diamond is for the real stropping. Don't use the two compounds on the same side of the strop because it will throw off your evenness. After you have your length of leather cut punch a hole about an inch from the top, put a stout piece of cord long enough to hook over a doorknob or whatever you're going to hang your strop on, make sure it's something very strong because you don't want it turning loose while you're stropping, this could cause a big mess!
Load the strop up with the compound just like you're coloring with a crayon, it's easier if you break off a hunk because the whole brick is unwieldly. After you get a good coat on the ROUGH side of the leather put a blade to it and strop it in, as it starts to turn black or shiny add more compound, it's very important to work a lot of the compound in before you get into serious stropping. You'll be able to tell when you have began to get it started because you will notice that it's polishing much faster. When you have a good start to seasoning then go to work with a blade, between strokes work more compound into the strop, it takes a while to get a strop seasoned but once you do it doesn't take as many applications of compound. A thing to remember, you cannot put too much compound on the strop, any excess that doesn't work in will just come off on your knife. Keep stropping and applying compound occasionally wiping your blade off and testing the edge. If I haven't answered any questions or you need to know more info feel free to e-mail me and ask, I'm always glad to help.
Best of luck,
Specops
