Cougar :
the pictures Mad Dog posted showed the knives being hammered with sticks. Cliff used the spine of another knife instead
When I first did this, I used a wooden club. It then struck me that odds are that I am not going to go out and carve up a club if such an incident happened so that was foolish. I then reasoned that what I would hit the knife with was mostly likely a lugwrench or something similar so I used one of the other knives I had with me (I rarely do any stress testing on one blade alone it can lead to gross errors in conclusions). As of late I have altered my method somewhat, since there was such an upcry about me hitting the TUSK with a "metallic object" I use a club now and then do the rest of the harder stress tests. I then go back and repeat the car cutting bringing along something harder to whack the blades with and repeat the harder stress tests again. As of yet I have not seen that induce a failure which is not surprising.
As for making sure its the same type of car etc., that is being a little absurd. That would only be necesary if Kevin had stated that his results were only relevant for that particular car, which would obviously be of little use. Making this restriction would be akin to asking someone to take a piece of spruce from the same tree that Mike used if you wanted to duplicate his chopping tests.
In any case, car roofs and such are made of mild steel now. This is very easy to cut through. If you have a blade with a strong point presentation like a khukuri you don't need a hammer, the khukuri will go through the roof quite easily. In general as for what it proves that a blade can do this, I no longer use it an indication of strength/durability as the stress level is too low and it does not induce failure even on low quality blades (Ontarios). So basically if you use this to "prove" the quality of your blades you are saying that the performance level is about that of a $50 production blade. I don't think that is much of a positive statement.
What do I use then? Currently a combination of digging, and controlled impacts on harder metals to guage edge durability and toughness. As a final step I will do prolonged full force high impact chopping on hardwoods (several sessions of about 1-2 hours, which is about 7500 chops give or take). This is done after a blade has passed all other work stresses as it can break blades apart badly. While it might seem like a mild stress because it is only wood, the impacts are very large due to the velocities involved, the chopping method used (high energy and strong follow through to break the wood if the cut is not completed) and the structure of the wood which is dead (for hardness) small diameter (to increase localization of force) branches.
-Cliff
[This message has been edited by Cliff Stamp (edited 01-31-2000).]
