- Feb 15, 2022
Long, long, time lurker of this forum.
Due to it, I own Esses, Beckers, a couple Tops, Ontario, Kabar and a handful of moras.
I have researched every little tip and trick over the years for sharpening knives and I still only achieve butter knife results.
I have 3 sharpeners, that I've owned over the last 3-4 years
1) Spyderco sharpmaker with additional fine diamond stones.
2) worksharp pivot response sharpener with extra stones/strop
3) worksharp field sharpener
4) knivesplus leather strop.
I hold the knife at the correct angles, mark with a sharpie, use light pressure.
When using the strop I move the blade away from the edge and try to find the correct angle by lightly taking the edge into the strop till it catches and then just backing off that angle and proceeding.
At the end of the day I rarely get anything sharper than when I started, and if I do, the edges are weird, they will somewhat shave hair but not cut paper or vice versa.
I've read about checking for a burr, and what that is, but I've never been able to feel a burr. I run my nail down across the edge and it never catches. I'm sure your feeling for something very subtle and it takes a trained feel, but all this stuff seems to take extensive experience with sharpening.
At of my knives are essentially 1095.
As of today, I am trying to sharpen my esse 6 with the sharpmaker set to 40 degrees, 20 each side, which I know little about these angles, but is what I believe esee reccomends.
I find that on one side the esee is removing the sharpie on the other side it is not. I'm guessing this is called an uneven bevel?
What do I do with that? I would assume I hold the knife at a sharper angle to start removing the sharpie for that side which I tried a little bit, and although that started getting some of the sharpie removed after 20 or 30 strokes, I still did not seem to get much improvement on the edge.
I know there are remedies for these type of issues, but what about somebody with no technical experience with sharpening? Im guessing that I wont even understand much of the responses as far as talks about reprofiling, angle technicalities, and other stuff that I won't even understand.
Sorry if I sound frustrated, been working at this for a long time and have read and watched so many videos with no success. But if anyone has anything else I should try please let me know, thanks in advance.
