- Oct 2, 1998
Also, what happened to the impossible to raise burr?![]()
It became impossible to see.
(Or feel, or detect.)
For want of bifocals, a country was lost.
I wrote/illustrated a book with sections on this, and that is one of the techniques I illustrate: viewing under bright light. Really works, and all I need is incandescent bulb.Just one note on workshop lighting. I’m 73 and am enjoying deteriorating vision. My workshop is lit up like an airport using led light panels to adjust the temperature for the lighting. But every knife I look from the spine to the apex with a bright flashlight. Any burr, no matter how tiny will stand out. I highly recommend this tactic for burr removal.
This is why I buy the frames, take them home, and put tape where line would be. I test on stairs, in car, etc., and then tell them where I want the line. Also, helps if you get the right RX which is not a foregone conclusion.That's why I got progressive sunglasses. Now the dash and radio are clear again!
I'm surprised at how well my cheapie bifocal glasses from Amazon are performing for reading and computer work. Much better than my old prescription glasses. Getting new eye test soon, so new glasses are will ordered. I tend to keep my old ones for too long.
If you can't see it, does it mean it doesn't exist?It became impossible to see.
I hate doing that because I see what I left behind.I wrote/illustrated a book with sections on this, and that is one of the techniques I illustrate: viewing under bright light. Really works, and all I need is incandescent bulb.
See above. LOLIf you can't see it, does it mean it doesn't exist?
Stop injecting logic into a hobby where I've lost count of the volume of collection I have.It's even clearer to me now (ironically), that my vision issues have completely driven my personal emphasis on observing cutting performance to determine if an edge is fully apexed and also if burrs are getting in the way of things. When I've needed to, I've relied on good, well-lit magnification to confirm was I was perceiving. And after confirming, I can then trust the conclusions I subsequently draw about whether the edge is fully apexed and cleanly deburred, based on observing how the edge is cutting.
Ann, I don't think it's going to be a technical review. It'll be limited to whether or not they fit me, and if I find them useful for any one or two possible uses I may find for them. I was only given a choice of 1.5x and above...so I opted for 1.5x since 1.25 is my usual for most cheaters.Blues Awaiting your review! The other measurement, and I don't know if Amazon asked you, is distance between pupils.
This custom number helps grind the lens to center properly on each eye. (Both pupils aren't necessarily equidistant from center.) Custom-made glasses would also put the sweet spot of the lenses higher or lower depending where you will wear the lens, high on the nose, low on the nose, etc.
The reason I asked is that depending on the person, those minor differences can make the glasses feel miraculous or not and taint the whole idea if one can benefit from glasses.Ann, I don't think it's going to be a technical review. It'll be limited to whether or not they fit me, and if I find them useful for any one or two possible uses I may find for them. I was only given a choice of 1.5x and above...so I opted for 1.5x since 1.25 is my usual for most cheaters.
On the topic of sighting burrs with lights...I use a Surefire I've owned for years which is within arm's reach of where I sharpen...and it usually puts the lie to my thinking I did a nice job.
Shining the light down vertically on the "apex" and moving it from plunge to tip and back.
It looks like this is with the bevel towards you. I generally look from the back towards the bevel, for burr removal.The reason I asked is that depending on the person, those minor differences can make the glasses feel miraculous or not and taint the whole idea if one can benefit from glasses.
I went into a drug store with some text. I tried every pair of cheaters of the same strength. Some of them worked really well, and others were really bad, useless. So, I think this can be what people pay for when they buy RX glasses--a higher suitability and better QC.
Here are some pics I took for a student. The lower pic has no issues--it has asymmetric bevels (pretty uniform) which you can see, but there is no crud-- no matter which direction you move it under the light. The top pic has numerous problems. Is this what you mean?
View attachment 3215991View attachment 3215993
Held b/c I’m right handed. As I mentioned, it did not matter how I held the knife. And it is possible to get burrs and defects from this perspective.It looks like this is with the bevel towards you. I generally look from the back towards the bevel, for burr removal.
