- Nov 2, 2010
I'm a bit of a data nerd, trying to categorize steel heat treat (HT) operations. The goal is to present a structured, easy to read recipe of "Here is how to harden 1095", "Here is how to anneal A2". These questions are fairly repetitive on the forums, so this effort tries to address that. I will also use these recipes to track what I have done to my own blades.
If this seems plausible, I'll turn it into a free website for bladesmiths to use.
HT Operations
These are procedural, so a "heat" can be a kiln preheat or the heating of steel, depending on when it happens.
Each operation can include notes that describe special instructions.
The operations can repeat, so multi-quench, interrupted quench, and other operations can be accounted for.
- Decarb protection: Using a foil wrap, salt bath, etc
- Heat : Rate ( degrees / minute ) and target (degrees)
- Blade put into kiln
- Quench : Medium (water, brine, plate, air, oil)
- Wait : Duration to wait after the previous operation.
Issues and assumptions
- A kiln is assumed. I assume that doesn't generally impact the operations used for torch, forge, salt bath, etc. I realize that solid fuel forges, fuel rich/poor propane forges, and other factors may impact a recipe, but I will ignore them for simplicity.
- Will a given recipe always be correct? No! Variations in alloying, steel batches, and other variables mean that the same recipe may not always work the same.
- Can there be multiple recipes for the same steel? Yes! For various reasons an air quench might be used instead of plate quench. That makes the recipes different, but not invalid.
- Every operation can link to a forum, wiki page, video or other resource to provide further information.
Feedback I'm looking for
Are any operations missing?
Is this a fool's errand?
Do you see any value in this?
What would make this effort really helpful to you?
I'm looking to give back to this community in the ways I can. I'm way less experienced/educated than Stacy Apelt, can't HT like Kevin Cashen, and have fewer dogs than Nick Wheeler
But maybe I can help some noobs by making a dent in the HT data arena.
HT Operations
