- Oct 18, 2001
Just FYI...
I know this was discussed in another thread...but the same folks are in this thread too....and it makes more sense posting this here, than in a YBB sales thread.
So, here we go.
Finally got a spare moment to take a handle apart, and wouldn't ya know it...had my camera handy too.
Too bad I didn't have a third hand to make a movie of it....maybe next time.
Anyway, enjoy the pics of the handle coming off of a nice Hanuman.
Task = Gently remove a hidden tang Hanuman handle
Total time = 15 minutes
1. Start with a 1/8" bit and drill a hole through the pin all the way to the other side. Move up to a fractionally larger drill bit until the hole is completely clear. Deburr the hole with a small file. 3 minutes
2. Hold the heat gun (on full power) about 1 inch away from the brass bolster - while keeping the heat gun moving around to evenly heat it. After about 7 minutes of solid heating, the laha starts to ooze...within a minute, it's like those "black snakes" you played with as a kid on the 4th of July. Laha practically jumping out of the joints! 9 minutes
3. Once the laha is just starting to bubble, I start twisting and wiggling the handle. By the time the laha is oozing rapidly, it quickly loosens up and slides right off like a roasted marshmallow on a stick. < 1 minute
4. Heat the bolster back up to soften the laha and slide it off too. < 1 minute
5. Heat up the tang and scrap it with a "craft stick" to clean up the tang some. 1 minute
First pic shows the handle right after it slid off. Yuck! You can see the hole drilled out of the tang. Also, notice the great gobs of laha that have oozed out the front of the bolster. (it's ok, don't worry about it) You can see the heat gun I use on the floor below.
Second pic shows the bolster removed, the handle cleaned up a little and the tang scraped.
Also shows why I say that partial tangs are every bit as strong as full tangs (in H.I. khukuris, that is)....that is a thick and solid tang!
After this, the easiest way to remove the laha is to get an old coffee can (or similar), get some water boiling, and drop the bolster in there while holding the tang in the water. Prop it up if you don't want to watch...but I like to watch....
The hot water boils off the laha and you're left with a fairly clean piece..and not too much mess....
All of this could be done over a fire. Just wrap the blade in wet cloth (or paper, etc) to protect the heat-treat and keep it wet. It will draw the heat away from the blade.
So, here we go.
