"Inexpensive" Wharncliffe options?
If you need a blade for like breaking down cardboard, the CRKT Edgie 2 is good option. I don't know if it is considered a wharncliffe, but it's close enough. I wouldn't suggest it for EDC, though. The blade gets VERY jagged, and... for lack of a better term... nasty.
Heh, but how can you go wrong with a knife called 'Edgie'? LOL
Just saw a new (or maybe it was old, just never seen it before) Kershaw, the Centofante-Onion. It is basically a Leek with aluminum handles and a true wharncliffe 440 blade.
Arthur Wright and Trevor Ablett do very cheap hand made wharncliffe/sheepsfoot slipjoint folders. Both traditional Sheffield little mesters
If you don't need a locking knife with pocket clip, the all stainless Spyderco Kiwi 3 is a great little slippie for around $20... I really enjoy mine :thumbup:
The Sanrenmu 702 would be your budget choice..Very well made and extremely high value. Kershaw Leek and spyderco centefante 4 would be other good choices..With most comparisons, the spyderco is the best of the bunch, but hard to find.The leek is very well made but less sturdy than the other two..I would go for the Sanrenmu 702.
The 3 together
Sanrenmu 702
Pink Leek
Centefante 4
The Leek is too strong, esp. if you get the steel handle ones (they are also the cheapest of the Leeks). The only real weakness of it is the tip being thin, but if want a really strong tip and blade, look at ZT or another brand designed to do so.
Man that sanremu is really nice, and cheap! Any reviews on it? That sure does fit the budget, but I've never heard of it :-/
I found the Sanrenmu 702 to have an annoying flaw. Oddly, it was clumsy to open with the thumb stud. That, combined with the thumb stud placement. I remedied the configuration by removing the thumb stud altogether, and using a Dremel cutting wheel to add some jimping on the back tang of the blade near the pivot end. This allows one hand opening using thumb pressure on the spine, sort of the way one might use a Bic lighter.
The 721 is another one hand opener Wharncliffe, with a thinner, skeletonized handle, a thumb hole rather than a stud, and a pointier, thinner tip. It also has a true straight cutting edge, like a Needs Work, and unlike a Leek and 702 which has a slight curve.
