- Jan 29, 2010
And the tan are my least favourite
Lol^^And the tan are my least favourite![]()
Once you get past 100 it doesn’t seem to matter anymore......plus you have made the dog house pretty livable and the dog does not judge either !!
...... I am THAT good now each 30mins pays for a Busse.....And all you worry about now is how long you have to work the curb to pay for those upcoming dings.![]()
...... I am THAT good now each 30mins pays for a Busse.....![]()
This makes me think that at least one of the operations during the heat treat gets the steel hot enough to put those carbide back into motion and that because the primary grind is thinner the blade is going to cool from the thinnest part first, causing these carbide to realign, following the sweep of the blade back up to the thickest part of the blade. Whatever it is it's really cool stuff and yet again another mystery of INFI.A comment on the youtube page from someone called NateAIM....
"This is mostly likely alloy banding. This occurs when the original cast ingot cools slowly enough that carbides precipitate out of solution so you have a mix of solid carbides and liquid iron causing these structures to become frozen into place as the ingot solidifies. As it gets rolled out into sheet these carbides are broken up and the carbon dissolves into the surrounding matrix leaving the alloy behind. Carbon moves at heat but the alloy doesn't. There's a good chance that is chromium. If you were to etch it, those spots would probably etch very light. The alloy tends to attract and combine with carbon and form the primary carbides and the secondary carbides during temper, so they are harder than the surrounding matrix and erode more slowly during grinding leading to the appearance that you see. It appears to follow the contour of the blade but is actually just rolled out in flat planes that are intersected by the shape of the blade. The amount of alloy banding you see there isn't ideal but probably doesn't represent a problem and is very common and simply less noticeable in knives finished differently.The particle metallurgy process such as CPM was invented to reduce this problem in higher alloy steels though the PM process brings different problems.
That is a good looking knife."
It's gluten-free, but INFI is loaded with bacon, so it's full of saturated fat.Ok, serious question guys. Is the INFI grain gluten-free?
