Also, I believe it is a 1975, or so, era knife.
Thank you for the info. No initials, that I have seen.Different and good filework..that's a plus along with the Stag. It might be Sambar and looks similar to Factory. But my expertise is more towards the 112. Is there initials on the back side of the lock bar? Sometimes Leroy Reamer ( Buck employee and famous for high grade Customs) would put LR there or even under the Stag..
Just began looking through your link. Wow, that is a truly detailed and interesting list of info and pictures, thank you!as ya said yours has been customized. not sure who did the work but.........Michael has done awesome work gathering up factory versions and putting this website together. while your exact knife won't be there, using the cues on the blade stamp will help to figure out which version it might be and details of that version. might help pin it down a bit outside of who did the customized work to it. sheath if original to that knife too as well since he has sheaths for versions and paperwork, etc.
Buck Knives: The 110 Folding Hunter
A Photographic History of the Buck Knife 110 Folding Hunterwww.historyofthe110.com
of course as Roger said stamp helps open that door right out of the gate
It seems to me that it has the tall BUCK logo on the blade. So V9 seems most likely.It seems like every variation on the two-dot (from Version 5 Variation 4 through Version 5 Variation 9) has a noticeable difference in the shape of the kick. With careful study you might be able to narrow it down to a specific one. As I look further I can tell it's NOT a V5V4 by the plunge line, and I think I see only two handle pins, so that may narrow it down to a V5V5 from 1974.
