hope i don't sound to stupid but how do i use a themocouple does it go in the forge or can i get the temp of the metal with it thanks chris![]()
Probably the best thing to use for HT in a forge is a pipe muffle. A heavy steel cylinder open on one end where you put the knives, I made mine with a small hole in the top so I could use my thermocouple inside it. That way there's no guessing. You still have to watch the colors to see when the steel is up to temp and count soak times, etc.
Wouldn't the thermocouple probe still be affected by the heat outside the muffle?
The thermocouple I used for this measures resistance across a tiny ball of metal at the end of the wires, so it is only affected by the heat at the very spot where that ball is situated.
