Cliff Stamp
BANNED
- Oct 5, 1998
I had a Becker C/U7 coming and wasn't really that interested in it, aside from having a useful benchmark. Combat knives in that class are usually too close to neutral balanced to be useful for heavy wood work (ATAK), and the ones that have enough of a blade heavy balance are often too thick to be able to cut anything (SOG SEAL 2000). However after reading through a couple of recent posts by RokJok, my interest was raised significantly :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=191387
http://www.bladeforums.com/forums/showthread.php?s=&threadid=191388
It seems that the level of cutting ability is very good and that it has a decent level of chopping ability for a blade of that length class. The knife arrived Friday and I did some work with it over the weekend comparing it against several other blades I had on hand of similar intent such as the SOG SEAL 2000, TAC-11 and Mission MPK A2 & Ti.
In short, it cut well, easily holding its own against the SOG, even though I had spent about an hour stripping metal off of the latter to convex the primary and secondary blade grind. With both knives at the NIB geometry the cutting performance would not have even been close. The handle on the C/U7 also allowed for a hook grip around the end to be used in chopping far more secure than on the SOG, and far more comfortable than the TAC-11.
I got some numbers for the cutting and chopping but they were only small samples and I was working with the NIB edge on the C/U7 and the edge that I put on the others, so that really isn't a meaningful direct comparison. I was doing it mainly to get a feel for the knife so as to roughly benchmark it, nothing more.
Aside from cutting, I also split up a few dozen rounds of about 1-2 thick, nothing major. These were all 1-2 year seasoned pine, fir and spruce which for the most part were partly frozen as I had just cut up the logs outside. The blade handled the splitting without fault. I was using another round as a mallet and the swedge did tend to cause the mallet to self destruct. The edge remained unaffected and showed no visible deformation let alone chipping, which was a good sign as I had some edge durability problems with a Machax.
In short I was impressed by its ability over a wide range of tasks. I definitely am looking forward to using it more. I would prefer a tip design that was optimized more towards strength over penetration, however that is simply personal preference. I have some issues with the handle, but they are minor and in part can be fixed by the user, such as a more aggressive surface texture (which has drawbacks obviously). The only real stand-out is that I would prefer the curvature to be more extended in the transition regions, more on those issues after extended use.
Some specifics :
The edge on mine was about 0.036 +/- 0.002" thick behind the bevel. This is decent for a tactical knife, more than you would need for a wood working blade, especially one of this size, but this blade obviously needs a bit more strength for harder tasks. I was pleased with the edge angle, as mine came out to 16 +/- 1 degrees, which means I don't have to re-profile this one right away. Combine the decently thin and acute edge with a high flat grind of about 4-5 degrees and the cutting performance is at a very decent level NIB.
Which brings up a small but important point. This blade is actually fairly wide. If you look a little closely you will see that the primary flat grind doesn't go all the way to the top. There is a strip of steel left at full thickness (3/16"). This gives added strength to the knife. Now the blade could have been left more narrow, and the same strength achieved by using a much more shallow primary grind, however this choice by Camillus gives the same strength with a higher level of cutting ability.
However, the sharpness NIB isn't going to impress anyone. It scored 185 +/- 8 g on the thread and 1.1 +/- 0.1 cm on the poly (1000 g load). This is about half that of a truly sharp blade. A few passes to test arm hair shaving (before the above cutting was performed), showed basically scraping ability, which is what I would expect given the poly and thread numbers. A quick check under magnification shows the reason. The edge was sharpened with a coarse abrasive and buffed, and is uneven with a slight burr. The NIB sharpness makes little difference to me, but is critical to some.
Here is a shot alongside the TAC-11 :
http://www.physics.mun.ca/~sstamp/images/becker_cu7_tac_11.jpg
Here is the SOG SEAL reground, along with two MPK's :
http://www.physics.mun.ca/~sstamp/images/mission_mpk_sog_seal_reground.jpg
-Cliff
Some specifics :
-Cliff
