First, the steel in discussion is 1095 - which does not have a temper embrittlement range concern. It is .95% carbon, .40% manganese, and the bulk mainly iron. It is not a high alloy steel and contains no chromium or nickel, which along with high manganese are the drivers of embrittlement.
In my opinion, martensitic embrittlement is not an issue at any temperature we would use on a knife HT. Temps up to 500F are fine in all knife steels with two one hour temper cycles.
Temper embrittlement is a mis-applied subject that affects high alloy and high speed steels used in turbine engines and high performance rotary parts ... but not knives .
If you have any doubt, look at the charts and temperatures used to temper 1095 springs. Springs in general are made from the same groups of steels we use for knives. If embrittlement was a big issue, they would be failing left and right. Springs are pretty well known to not be brittle ... and to be quite tough.
In my understanding, temper embrittlement is a concern for high alloy steels at 700-1000F. Time is a factor, too. It is not an issue on most steels with less than .50% Mn, and the alloying ingredients have a lot to do with any risk. Chromium and nickel are the primary culprits if present in larger amounts. It is also time dependent, and longer times and slower cooling rates foster it. Tungsten and molybdenum are added to steel partly to decrease embrittlement. Another issue is where the embrittlement happens - in the grain boundaries. In steels with large grains, this can be a big issue. Knives are made with very fine grain ( hopefully). This makes many more places for the troublesome carbides to get tucked away with no strength problems. The larger the carbide size, the more the issue. Carbon-iron carbides are pretty small and won't effectively change the spacing between grains. Carbon-chromium carbides are big, and thus make a more likely dislocation point between the martensite grains.
BTW, One reason I recommend water quenching from black heat ( about 900F) in cycling and annealing steel is to stay out of any embrittlement range in slow cooling.
