How To Install M&P Sight?
So I bought a set of hiviz fiber optic sights for my m&p 2.0. The rear sight went in perfect. I bought a set of nylon punches to install the front sight and ended up mashing the ends. I sanded down the sight with 120 grit, maybe 15 4" passes from both directions (30), pressed in 1/3 of the way. Had to use a 1" brass punch to get it in the rest of the way. Found the sight to be crooked once installed (may have slipped the nylon punch when it cracked).
Did I sand too little out do they press in hard anyways? It came out easy. No deformation of the slide dovetail or finish damage.
How much do you have to sand off on average? I ordered a 5/16 brass punch to install the new set I got coming. The directions say to be able to press it in 1/3 the way. Is that 1/3 into the slide dovetail or 1/3 of the sight dovetail?
Any other tips? I think I'm going to loctite the screw before I install the rear sight. Can I use ballistol in the dovetails before I install them or will that make them slip after being installed? I want to get them right the second time around.
The M&P front sights are usually pretty snug. I've installed several with just an aluminum punch, but recently purchased a sight pusher.
A sight pusher is the way to go if you don't mind the expense, but a punch works too.
I don't know exactly how much material I typically remove, but it's not much. The sights need to be reasonably tight so they don't fly off during recoil.
Maybe try tapping it in using a block of wood or micarta. This works better than a punch IMO, because the force seems to be more evenly distributed.
I was going to say a sight drifter is much easier and not so much chance of damage. You an buy some sight drifters very reasonable anymore. And yes alot of guns are more difficult then say a standard 1911 so it's a good investment if you shoot much.
The ballistol shouldn't cause it to slide but it can gum up a bit and attract debris.
