Interested in making knives, but would like an idea of the cost investment
Hi,
I'm currently a student enrolled in a 4 year university. While I am set to complete at the end of my 4 years and to hopefully find a viable career, I would like to make knives as both a hobby and small source of income. This summer depending on my available time, I would to start learning and practicing. That said, I can't afford spend too much money on all the different tool and equipment knifemaking would require. My plan would be to outsource heat-treating and to find someone to waterjet blanks. As for the shaping of the handle, grinding, and finishing the knife I plan to do all that myself.
That noted, what is a realistic estimate for the money needed to invest in belts, a grinder, clamps, files, and other related pieces of equipment that entail the tasks mentioned above? What would a decent grinder cost that would do the job?
Thanks,
Julian
Hi,
Thanks,
Julian
The Count will be by shortly most likely with an excellent standard reply, so first piece of advice, pay a lot of attention to that, there's a lot of stuff you'll need to soak up and understand to make any informed purchases and make decent knives (most likely after a good amount of time and practice). Some jump in and are very good, but they usually either spend months planning their first knife, or have prior experience as a craftsman or artisan of some type.
If you have no tools at all, I'd say you'd easily make it into the hundreds on basic hand tools if you're serious about doing a good job.
This is a VERY rough guess for a few price ranges starting from zero tools of any kind, and could vary wildly:
Lowest- Make a couple simple knives to test the waters, hand methods only (hacksaw, files & file jig, sandpaper, hand drill), found materials for handles, potentially as low as $100 including a single small bar of a basic quality carbon steel.
Low end powered setup (but workable)- 2x42 grinder, drill press, decent materials such as micarta, blade steel, belts, other tools and supplies, probably $500+
Decent powered setup- Low cost 2x72, drill press, decent assortment of hand tools and supplies, belts, steel, etc., at least $1000
If you have little to no experience in this kind of work, you may want to consider paid lessons or LOTS of lurking at hammer-ins and any time you can get around makers, for your own safety. This type of work is not figure it out as you go, as far as what is and isn't safe on high speed machinery that can kill you. We unfortunately lost a maker recently due to a buffer accident, and it's definitely not the first one we've lost either. It's a risk that even the massively talented and massively careful are exposed to, and not to be taken lightly.
You can make a very nice knife using hand methods only and if you are starting with nothing it will be very expensive to gear up to even half-decent compared to an average established maker. I already had a large tool set and shop, and still had to make a significant investment to make things work for me. I'm still not even at "decently well equipped level" yet, and I've spent thousands and thousands. If you stick to one or two simple things and do them well, you may be able to gear up for cheaper, but if you do a bunch of different grinds, styles, finishes, the tooling can stack up fast.
If you make a couple with hand methods, you will have plenty of time to stop and think, which is VERY important on your first knives, you will have time to correct small errors before they become huge, and you will learn a tremendous amount of dos and don'ts very quickly. You'll learn a lot about where the geometry needs to be, and have a lot better time getting it there accurately than going straight to the grinder for your first blade. I feel that at least for some makers, doing a few by hand with a file jig can have a huge effect on their quality when they do switch to a grinder. There is nothing wrong with making a blade with a file jig, in fact it will likely get you saleable, attractive blades much more quickly than starting out on a grinder will, and you'll probably learn more about material removal as it relates to a knife.
Thanks for the reply. I do have some tools already and I'm willing to expend the time to learn and do things right. Given your advice starting with hand methods only sounds like a good way for me to start and get a feel for what I want to do. I'll be doing a lot more reading and asking, but your reply was pretty helpful.
Before you make it your job, and before you spend all your money to do so, try making just one or two by hand.
See the filing jig
The Count's Standard Reply to New Knifemakers V36
Answers to a student are different than to machinist
With members worldwide, you may have a local supplier, hammerin or neighbour.
Join our community;fill out your profile with (Country, State, City), age, education, work and hobbies so we get a sense of who you are.
Basics
Absolute Cheapskate Way to Start Making Knives-PDF
http://jubilee101.com/subscription/pdf/Tools/Making-Simple-Knives---12pages.pdf
Web Tutorials
Detailed instructions http://www.bladeforums.com/forums/showthread.php?t=694673
Things I Advise New Makers Against-PDF http://www.mediafire.com/?8og1ix21j9dcz4n
Handle Tutorial - Nick Wheeler-PDF http://www.mediafire.com/?02ra4do6xyzayeq
http://www4.gvsu.edu/triert/cache/articles/nw1/scales1.htm
http://www.bladeforums.com/forums/s...Wheeler-s-Steel-*-Stuck-in-the-metal-with-you
http://www.bladeforums.com/forums/showthread.php/956343-Damascus-integral-tag-along
Bob Egnath how to http://www.engnath.com/manframe.htm
Books
A list of books and videos http://www.bladeforums.com/forums/showpost.php?p=9435307&postcount=43
BladeForums - E-books or Google books http://www.bladeforums.com/forums/showthread.php?t=603203
Books I like:
David Boye-Step by Step Knifemaking
Tim McCreight-Custom Knifemaking: 10 Projects from a Master Craftsman
Clear, organized, available inexpensive.
Forging Books:
Lorelei Sims-The Backyard Blacksmith - colour photos - forging - no knifemaking.
Jim Hrisoulas
The Complete Bladesmith: Forging Your Way to Perfection
The Pattern-Welded Blade: Artistry in Iron
The Master Bladesmith: Advanced Studies in Steel
Machine Shop Basics -Books:
Elementary Machine Shop Practice-PDF Http://www.archive.org/download/elementarymachin00palmrich/elementarymachin00palmrich.pdf
The Complete Practical Machinist-1885-PDF http://ia700309.us.archive.org/6/items/completepractic00rosegoog/completepractic00rosegoog.pdf
Right Click and save
The $50 knife Shop-not recommended
Great title, but NOT gospel.
Forging is NOT necessary; file and grind (stock removal)
"Goop Quench" is Bullsh*t
Back when they used whale oil, it was still liquid oil
Use commercial quench oil & match oil speed to steel type;
Grocery store canola oil works for 1084
Junkyard steel requires skill and experience to identify and heat treat
Forget Lawnmower blades and railroad spikes, start with a new known steel
Good heat treat needs accurate temperature control and full quench
Proper steel like 1084FG from Aldo is inexpensive and quench in Canola
Cable damascus is an advanced project has no place in a beginner’s book
The grinders are the best thing about this book, but 2x72” belt grinders plans are now free on the web
Video
Don't be this guy
http://www.youtube.com/watch?v=gEOTtslHARQ
Heat Treating Basics Video-downloadable
Right click and save this. Watch it daily for 10 days http://www.archive.org/download/gov.ntis.ava08799vnb1/ava08799vnb1_512kb.mp4
Safety-video
Right click and save this. Watch it daily for 10 days http://www.howtomakeaknife.net/FreeStuff/SafetyVideo.wmv
Many videos are available, some better than others
The best beginner videos I have seen:
“Steve Johnson-Making a Sub-Hilt Fighter”
"Ed Caffrey - Basic Bladesmithing-Full DVD-ISO"
“Custom Knife Sheaths -Chuck Burrows - Wild Rose”
Paul Long's sheath work & videos are recommended, but advanced-with inlays, tooling and machine stitching
Green Pete's Free Video
Make a Mora bushcraft knife, stock removal, hand tools, neo tribal / unplugged heat treat
Use a piece of known 1084 steel, not a file. This as an example of doing it by hand with few tools
"Green Pete" posted it free
Be sure to look at the other titles I mentioned too – search knifemaking torrents
Greenpete Knifemaking Basics-on TPB
http://thepiratebay.org/torrent/499...femaking_Basics_-_Make_a_Mora_Bushcraft_Knife
How to download that video
http://www.utorrent.com/help/guides/beginners-guide
Videos for rent,read the reviews, Some good, some bad, expect to wait months and there have been no new videos in years.
http://smartflix.com/store/category/9/Knifemaking
Knife Design:
Think thin, small, simple and fixed
Forget swords, 1/4” thick stock, saw-teeth, guthooks, crazy grinds and folders for your first knife
Look at hundreds of photos
Lloyd Harding drawings, Loveless book & Bob Engnath Patterns
Bob Engnath Patterns PDF http://www.mediafire.com/?qgx7yebn77n77qx
http://knifemaking.altervista.org/index_disegni_en.html
Start with a drawing and post it before you work on steel, we love photos and can comment before you start
French curves, graph paper and erasers are vital tools
http://3.bp.blogspot.com/_bHFtVNs9tWA/TEj5Quiq1ZI/AAAAAAAAAI0/rn2EoHoXpVc/s1600/The+French+Curve.jpg
http://www.bladeforums.com/forums/showthread.php/1147466-How?p=13120810#post13120810
Then a cardboard cutout template & with handles, pins and such
Use playdough to shape a handle, good handles are not flat
How to post a photo
http://www.bladeforums.com/forums/s...AL-Displaying-your-photographs-on-BladeForums
Draw Filing Demonstration
YouTube video -Draw Filing-for a flat finish http://www.youtube.com/watch?v=Dec78RQsokw
Nick Wheeler- Hand sanding 101 https://www.youtube.com/watch?v=4I4x4QLpfnk
Steel
The “welding steel” at Home Depot / Lowes is useless for knives
Buy new known 1/8” annealed blade steel
Forget lawnmower blades ,files, railroad spikes and other unknown junkyard steels
For the work involved, it is very cheap to buy and use known good steel
You will spend more money on sandpaper or soda pop than you will for steel
If you send out for heat treating, you can use
Oil quenched O1, 1095, 1084
Or air quenched A2, CM154, ATS34, CPM154, 440C, Elmax plus many others.
For heat treating yourself with minimal equipment, find Eutectoid steel and quench in Canola oil.
1084FG sold by Aldo Bruno is formulated for Knifemaking, Cheap & made for DIY heat-treat.
http://njsteelbaron.com/
Phone # 862-203-8160
His telephone service is better than his website.
Suppliers List
http://www.bladeforums.com/forums/showthread.php?t=699736
Heat Treating
http://www.bladeforums.com/forums/showpost.php?p=9143684&postcount=7
You can send blades out for heat treating $10 or $15 for perfect results
Air Hardening Stainless Steel Only
Buck Pau Bos -Be sure to check the Shipping and Price tabs
http://www.buckknives.com/about-knives/heat-treating/
http://www.texasknife.com/vcom/privacy.php#services
Oil Hardening Carbon Steels and Air Hardening Stainless Steel
http://www.petersheattreat.com/cutlery.html
http://www.knifemaker.ca/ (Canadian)
FAQ's
http://www.hypefreeblades.com/faq.html
1095 is a bad choice for a beginner with limited equipment to HT themselves
1095 is "Hypereutectioid" and needs precise temperature control and proper fast quench oil Like Parks 50 or Houghton K
Kevin Cashen - 1095 - hypereutectoid steel
http://www.bladeforums.com/forums/showthread.php/673173-Working-the-three-steel-types
If you are sending one or 2 knives out for heat treatment, use 154-CM or CPM-154 CPM-s35vn Elmax, and ship it out to TKS -Texas Knifemaker Supply
It's the cheapest way to do 1 or 2 due to minimum charges
Quenchants for Oil hardening steel
Forget Goop Quench and Motor oil
Use commercial quench oil & match oil speed to the steel type
Explanation and classification oil speeds
http://knifedogs.com/showthread.php?28197-Hardening-II-Quenching
Grocery store canola oil works well -if you use the right steel like 1084
Brine and water are cheap for "water hardening" steels W1 and 1095, but use fast oils Parks 50 & Houghton Houghto Quench K
If you use water or brine, expect broken blades
Hot steel beats plastic, Don't quench in plastic pail
Glue – Epoxy
Use new slow setting 30 min high strength epoxy to attach handles and seal out moisture
Slow epoxy is stronger and gives you time to work
prep, measure, mix are key in gluing.
Surface Prep is vital, drill tang holes/ grind a hollow, roughen the surfaces with abrasive or blasting is best
Ensure the surface is clean including fingerprints, wear vinyl or nitrile gloves
Use Acetone or Blasting
Don't over-clamp.A “glue starved joint” is weak
West Systems G Flex http://www.westsystem.com/ss/g-flex-epoxy/
Find it locally http://www.westsystem.com/ss/where-to-buy/
Brownell's Acraglas
JB Weld-leaves a grey line
Grinder / Tools
Hand Tools
You can do it by hand with files and abrasive like the Green Pete video.
Use 1084 instead of a file, spheroid annealed steel is butter soft
Stacy - 10 Tools
http://www.bladeforums.com/forums/showthread.php/1049666-Ten-Tools?p=11983527#post11983527
Filing jigs
http://www.flemingknives.com/imagesPrime/FileStation/KPicB007.jpg
Http://farm9.staticflickr.com/8486/8152684286_312b9fc8da_b.jpg
http://www.youtube.com/watch?v=r9iNDRwwBQQ#t=330
Grinders
A professional three or four wheel 2x72 is worth it
In my opinion, variable speed and a small wheel attachment are essential on a good grinder.
Tracking problems are usually solved with belt tension. It needs to be way tighter than you first think.
Entry Level Grinders
Sears Craftsman 2x42 belt grinder
Low Speed Modification Craftsman 2x42 belt grinder http://www.youtube.com/watch?v=2qfYT_m2Tw0
Commercial Production 2 x 72” Belt Grinder Reviews
http://www.prometheanknives.com/shop-techniques-3/grinders
DIY 2 x 72” Belt Grinders
KMG Clone Free Plans
There are some things that need to be modified
http://www.knifenetwork.com/forum/showthread.php?t=62944
https://drive.google.com/file/d/0B_e1p6D-UyycWHd2V0VMTFVJMDQ/edit
NWG No Weld Grinder $25 plans
http://usaknifemaker.com/plans-for-the-no-weld-grinder-sander-nearly-50-pages.html
EERF Grinder (EERF =“Free” backwards)
http://www.wilmontgrinders.com/Pages/EERFGrinder.aspx
http://blindhogg.com/blueprints.html
http://polarbearforge.com/grinder_kit.html
What Belts to buy?
Every maker has a preference, new belts come out all the time, search for recent info
Ceramic, trizact and structured belts are expensive and have long life. Aluminium oxide are cheap and wear quickly
Some belts have rigid backing, J-flex have soft backing and can blend curves.
Blaze and Cubitron are popular
VFD Variable Speed made simple
Step pulleys are not as cheap as you think
Maska steel pulleys, plus shaft, bearings, belt
It all adds up to 1/2 the price of a sealed NEMA 4 VFD like a KB Electronics KBAC-27D
I like direct drive with no belts, a VFD and 3 phase motor for about $200 over the price of the step pulleys with fine instant control.
NEMA 1 VFD’s metallic dust intrusion will smoke it.
Motor
3 phase 220v 1.5 HP motor, TEFC, frame 56 or 56C,
RPM is up to you some use 1700 RPM at double speed.
Make sure it has a foot base for the KMG and NWG, a C flange face mount for Bader, Bee, Wilton and GIB styles.
I get them on ebay, even with $100 shipping to Canada I save $ on used motors
The 1.5 HP combination is the most common
It allows you to plug into any 110vac, 15 amp outlet.
A 2 HP motor requires a 220vac input.
VFD
KBAC-27D
http://www.kbelectronics.com/Variable_Speed_AC_Drives_Inverters/AC_Drives_NEMA_4X.html
http://www.kbelectronics.com/manuals/kbda_manual.pdf
Use the Distributor Locator to find a local source, online sources may be cheaper.
There are cheaper, but the only VFD I found that runs a 1.5 HP motor on a 110v 15 amp input is the KBAC-27D
It is NEMA 4 sealed
Good community and company support, manuals, diagrams, photos and settings.
Travis W reports running 2 HP on a 110v circuit, but I haven’t tried it.
Hookup is simple
http://www.beaumontmetalworks.com/VS-setup.html
Safety Equipment
Protect -Eyes, Ears, Fingers, and Lungs – remove jewellery and use safety gear.
Respirators
Chronic lung disease and cancer really suck the joy out of life.
If you can't breathe, nothing else matters.
Wearing a mask and glasses on the top of your head doesn't Count.
The minimum I use are silicone half masks with P100 Filter
The soft silicone masks fit better
3M 7500
http://multimedia.3m.com/mws/mediaw...Ox_Uev7qe17zHvTSevTSeSSSSSS--&fn=CH7500FP.pdf
and North 7700
http://www.amazon.com/North-Safety-770030L-Silicone-Respirator/dp/B002C08YCW
http://www.amazon.com/North-7580P100-P100-Particulate-Cartridge/dp/B000UH6PSE/ref=pd_bxgy_hi_img_b.
Use VOC & P100 combo cartridge for acetone and glue fumes.
Prefilters can snap over the main filter for longer life.
There are 3 sizes of face get fitted in person
Shave, test the fit every time.
For beards
3M PAPR
Resp-O-Rator
3m Breathe Easy
Trend Airshield Pro
Air Cap II
Search
This searches BF well.
http://www.google.com/cse/home?cx=011197018607028182644:qfobr3dlcra
Get rich making knives ?
http://www.bladeforums.com/forums/s...knife-making-worth-it?p=11980504#post11980504
Visit a shop in person
http://www.bladeforums.com/forums/showthread.php/1166688-How-to-get-a-shop-invite
V36 December 2014
You better buddy up with someone in the enginering department and get them fab you up a grinder ;0)
I actually am an engineering major and I've seen many labs and shops with such equipment--though I am uncertain that they would let the university equipment be used to make knives.
I've been thinking lately that I would like to start making knives again, so thank you to Bladenoobie for starting the thread, and thank you Count for the standard reply. I'm bookmarking this.
So you're half way there, all you need to do is find one of those shops that rent work space and equipment, and build a high end grinder, probably save a grand right there when you are ready to move up
I don't think water jet is the way to go unless you're making a bunch of knives. Cutting the 2d profile with an $80 bandsaw takes a few minutes. Filing or grinding bevels and finish work takes hours.
Step one: Go to the bank and empty all accounts in cash.
Step two: Dig a hole.
Step three: Throw all your money into said hole.
Step four:......
Just kidding. I'm a staunch advocate of starting with files. Jigs too if need be, but it will help you with feel and geometry later when you're removing metal at light speed with a 36 grit Norton blaze on your 2x72...
And read the count.
And Hi guys... Long time no see!
And I second a bandsaw. This kind of rig can be had on a sale day for less than $100 including the blades. Making a mount is easy. I welded a larger work surface on it though. Blows through anything you'd ever want to cut...
I use a water jet for anything that I need 25+ of. For a handful of things at a time the bandsaw is hard to beat. I cut a hole in the bottom cover too so it can be cleaned out quickly...
Cheers!
I started with a file, hacksaw and some clamps... then a $45 drill press and a used $30 4x36 grinder.
Hog metal with the grinder, use files to do or clean up your plunge and draw file your bevels. Send off for heat treat.
Next you will really want a better grinder that will cut a better plunge and can be slowed down... after that you will need just one ore tool until the next is acquired for an indefinite period. :D
For profiling you can just chop a bar with your hack saw and grind to profile. I'd do a bunch by hand first before considering waterjet, that way you can make small changes as you go.
I have been making knives full time for 4 years and somehow started off as a full time maker. I am still putting everything into the knife shop as I am moving to mostly locking folders.
Apply for summer work first. Make a few on your time while you earn money. Chances are since you only have a couple of months until summer you might be better off working and actually making money while you practice enough to have a product someone would choose to buy.
That's the last step that sometimes gets left out. Will you have something that someone wants to buy? Can you sell? How?
Take that against the nearly guaranteed several thousand bucks you will get from landscaping or painting or something.
And you have to recoup your investment before you can begin to make a profit.
So maybe job first and see about getting into making knives in the evenings would be my advice.
Most of those labs have student aids that help the prof who runs the lab. Ace that class and get to know that prof. Show that you are serious by designing your knives in CAD. Create the tool paths in G code and use the CNC machine to make some knives. They will probably have some heat treat equipment there too. You will have a few classes that use those labs as well.
My only advice is you better have at least a little artistic ability or you will struggle with this forever.(Like me)
You will spend less tooling up, if you have a nose for second hand machines- and the acumen/obsession to acquire and rehabilitate them. That is a description of me, by the way.
A basic understanding of shop theory will take you a long way- have you made things much before, worked with your hands, run basic power tools? Do you have a careful eye for material removal? If so, I'd say its OK to skip the knives made by filing etc... a couple of those may turn you off of knifemaking entirely. Of course, the difficulty of learning to accurately freehand belt grind blades turns many people off of the trade, as well...
I'd say your best bet is to find a maker or two to visit, try your hand at it, see how you like it and get some in-person advice. Sometimes guys like this may have equipment to pass on, or friends selling tools, or even help you make a grinder or something. I know I've done that, and I've been helped that way in the past, as well.
I started with a hacksaw, corded drill with one 1/4" drill bit, files and sandpaper. I heat-treated between two cinder blocks with a propane torch and quenched in my mother's cooking oil. I eventually bought a drill press and 4"x36" grinder. One improvement you can do to a 4"x36" grinder is to add a two inch platen on the face and then cut your belts in half. This allows you to do plunge cuts.
The biggest thing you should do before anything else is to hook up with fellow makers in your area. Most knifemakers will open up their shop and teach, in my case all I had to bring was a case of beer.
