America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Because there's no such thing as a 20 inclusive degree flat grind. A ten degree per side bevel on a 1/8" thick blade is going to go about 5/16", a 1/4" beast will have a 5/8" wide bevel. I don't personally know of any quarter inch blades that are only a bit over half an inch tall. The scandi grind is a primary bevel that is the same as an edge bevel applied with other grinds. The increased friction is from the fact that the entirety of the bevel is that much more obtuse. When used for a planing action on wood, it isn't a problem. It increases the human hand's ability to control depth of cut by giving that nice wide reference bevel. But when trying to cut through something, it translates a much greater amount of the applied force to the plane perpendicular to bevel. The further the bevel deviates from 0 degrees, the more wedging force and less cutting force.Speaking to the amount of friction generated by the backbevel, why would that be any greater than a flat grind 20 degree edge with a 30 degree primary bevel
It's good steel hardened to around 60. My little opinel is at 20 and it's edge lasts forever and it's a softer steel.
I too have taken to putting a 30 degree inclusive microbevel on my Moras. I just use the Sharpmaker, about 50 passes each side, each grit, and then strop with the green compound. Still scary sharp but more durable.
This is good to know------thanks! (even though that's what I'd already done anyway.........:S)
you're talking about stainless opinels right ? because the carbon ones are over 60 hrc from my estimation. i've seen one tested at 62 or 65 iirc but can't find the source right now.
Perhaps things have changed. I have two 20+ year-old Opinals in carbon steel, purchased months apart from different vendors, and they are quite soft.
