- Nov 14, 2017
IDK, I only have a 1941 Greenlee catalog for reference. Here is a model that looks to me to have similarities to yours:rjdankirt, It seems that the Greenlee I posted was also hollow ground on the bevel side at one time also. I think it was a factory grind but am open to being wrong about that.
I've got the classic version of this knife. It's the same blade but with red barrel shaped handles. It's a bit of a different beast compared to a normal draw knife because of the double bevel and the handle arrangement. I find it makes a great wasting knife but is a little too aggressive for fine work. Push or pull works equally well although I find you want to watch where your knuckles are going hit with the push stroke since they will connect with the stump before the blade does.Some more on the Mora 220. I don't remember seeing one before.
About Wood Splitting Knife 220
You can use the kindling knife to make smaller pieces of wood so that you can get your fire going more easily. It has a carbon steel blade and a double handle made of birch wood, making it effective and simple to work with.
Mora doesn't say anything about using it for carving or as a push/draw knife. The cutting edge is double bevel. Knife length is 366mm (14.409 448 819 inch). Blade length is 114mm (4.488 188 976 4 inch).
From Garrett Wade:
Bob
I googled them. They look nice. A little sticker shock though.lie nielsen still makes curved draw knives, based on an old witherby pattern, though not as sharply curved as the OP's they're commonly used for de-barking. The curve gives a bit more bite in my limited experience.
