Wrought Iron sound interesting; in fact, I've been searching the internet for sources. Is there such a thing as wrought iron bar stock? I haven't been able to find anything yet.
Or, could I heat it up with an O/A torch and hammer it flat? What do you do with wrought to finish it?
Try taking a short section of cable (wire rope) degrease it and then flow brass or copper into the areas between the wires using an acetylene torch. Then work to shape.
The wrought iron I've seen used was etched with FC to finish it out. I have some but haven't used it yet. The salvage WI from USA Knifemaker is pretty rough so be aware of that before you order. That isn't necessarily a bad thing, just something to think about. I believe they have some other that isn't quite so rough. I haven't looked in awhile though.
How about monel metal? it has a little different color than SS, polishes nicely, and is super corrosion resistant as well as having better scratch resistance than nickel silver. It can be hard to work with though.
