I only sharpen the 'bottom' blade for the tanto, and leave the 'forward' blade as factory sharp so I have something to compare against. You are probably right about rounding the middle point (or transition point) and from what I have learned that means I just need to not pull directly off the rods when I get to that part. My SM technique is not solid right now, I am not ashamed to admit that haha. BHQ claims that the blade thickness for this knife is .10'' but I don't really know if that's thick or not. I probably do round the blade when stropping, because I am not gentle when stropping with my cardboard so I will need to rethink my technique. I will try to return to practicing as soon as I have free time from school, because midterms are midterms.Hmm. It sorta looks like you aren't touching the edge near the heel of the blade. But that could be a trick of the light. On the second side, I think I clearly see that the edge bevel is wider near the heel. That's not all that uncommon either. The heel is one of the worst areas in factory blades. They tend to have lots of geometry problems there.
I think you might be turning your tanto "middle point" into a rounded belly. If you want to keep the tanto shape with the sharp transition between the two planes, then you should sharpen that blade in two sections. Do one straight section, stopping at the transition point. Then do the other straight section. Again stopping (or starting) at the transition point.
Blunting might not be the perfect description. "Rounding off the edge" is the term that's use the most here. It's very easy to do this with a strop because of the soft substrate. But you can absolutely round off a sharp edge by having poor angle control also. I'm not sure if that's your issue or not.
This implies that your SM technique is solid. ...or maybe it's just that you're having trouble with a blade with a thicker grind. The blade in the picture looks very thick. It's much harder to get a good edge on a thick blade. Thin blades are comparatively easy.
It might be time for me to re-do that post. When they changed the forum software all of the internal links in that thread stopped working. Plus it's formatted goofy because the forum software wouldn't accept certain posts. Yeah, I think it's time to re-do that. Thanks for mentioning it!
Brian.
