- Dec 28, 2000
Jazz1, you might want to look at the pictures I posted again...
I just got my Native in and I realized this. I got them out and tried them side-by-side.Put a flat grind on a Spydie Native and you have virtually identical cutting tools.
This is not true. As I mentioned above, I use mine often without choking up on the choil, and you get a pretty different grip. With the choil-grip, you hold it "above" the knife. With the regular handle-grip, you hold it "above-and-behind" the knife. You get a fairly different cutting style.but the reasoning you guys use indicates that to get that leverage, YOU HAVE TO CHOKE UP, no choice!
I'm not sure I understand. In the "closed" position, the SnG stops due to the knife blade choil meeting up with the backspacer. In the open position, the blade stops due to the lock bar pushing the stop-pins (thumb studs) against the two slabs. As far as i know, nowhere is there a difference in fixed or floating tension.Also, If I read everything correct, the lock on the SnG stops to a certain position on the tang due to the 'fixed' tension on the Ti-handle slab, while on the Sebenza it stops because it hits the lightly angled ramp/tang.
The Seb's lockbar pushes the blade tang against the stop pin.
The SnG's lockbar pushes the stop pins against the handle slabs.
Hope this clarifies (or adds fuel to the fire).
The SnG has a small (really small, but still noticeable) up-and-down blade play. The problem is that the locking Ti bar is not engaging far enough. It travels about 3mm across the lock-cut-out in the blade and than stops. The cause of the stop is not that the locking bar touches the blade but the bar is just not spring-loaded any more. If I push the bar toward the centre of the handle the bar goes another 1,5mm and locks the blade PERFECTLY. But when I take my thumb off the locking bar and let it free than the bar springs back this 1,5mm to the side and the lock-up is not like I expect in SnG.
The solution is simple load some more spring force to the locking Ti bar. So it looks like I just should take my torx set (Im a hobby knifemaker so I have my shop, tools and experience), take SnG apart and bend the Ti 2mm further. But is this so simple?
