A.McPherson
- Jan 27, 2012
Thank you.
Lol!
Just what do you mean by "preheat"?Honestly I never heard before this thread that it's OK to skip preheat.
That's right but I've never removed the parts between the preheat and the ramp up to aus soak.Just what do you mean by "preheat"?
When I think of preheat I think of stabilizing oven to a set temp, perhaps 1725°F, putting blade in to soak for a specific time (10 minutes perhaps?), removing blade, ramping oven up to 1975°F allowing it to stabilize, then putting blade in for final aus soak. In this case the 1725°F would be the preheat. Is this anything like you're calling preheat?
I don’t sharpen a blade until the handle and possible sheath are done, absolutely no reason to handle a sharp blade for the rest of the process.It is funny to me that this thread is the first I have read about putting the parts, other than 1084, in at austenitizing temps. I've been doing what Jason described for a year now (in at near data sheet "preheat" temps, preheat, ramp to aus, hold, remove parts and quench). Makes me wonder what other fundamental steps I should be doing differently! You guys all sharpen blades as soon as bevels are ground, right?
That was meant as a (clearly poor) joke!I don’t sharpen a blade until the handle and possible sheath are done, absolutely no reason to handle a sharp blade for the rest of the process.
Actually there is a good reason to sharpen as soon after HT as possible...That was meant as a (clearly poor) joke!
I always sharpen the blade before I finish the knifeIt is funny to me that this thread is the first I have read about putting the parts, other than 1084, in at austenitizing temps. I've been doing what Jason described for a year now (in at near data sheet "preheat" temps, preheat, ramp to aus, hold, remove parts and quench). Makes me wonder what other fundamental steps I should be doing differently! You guys all sharpen blades as soon as bevels are ground, right?
I would like to hear your opinion about this .................... https://www.bladeforums.com/threads/thermocouple-position-in-oven.1765879/Different ovens call for different approaches. IMO the Evenheat should be soaked for an hour at some temperature above your austenitizing temperature. Use a fast ramp program to get it there and hold it a while. When you open the door and put your work in, it will drop a lot. With some experience it will drop to a temp just a little below your target temp so when you switch to your austenitizing program (with slow ramps) it won't nuke your work with those exposed elements that are inches away. The temperature difference between your cold knife and that hot oven will prevent that little bit of overheat from actually overheating your work, whereas those exposed elements can certainly overheat spots while trying to get the entire oven up to temp. This, in my opinion, is the best approach for this particular oven and its limitations.
It would be lovely to preheat, but you're going to need two ovens to do that and it really doesn't serve much purpose in a knife. Attempting to preheat in a single Evenheat subjects your work to those hot spots while it ramps up and is no bueno.
I didn't see this I am sorry! I can only say what I was told by evenheat so don't hold my feet to the fire here but they said that the PID is programmed for each specific oven and resistance of coil and Tprobe, and that if you have a model with the APO (auto power off when door open switch) switch, the PID knows that the oven was opened and will increase wattage as quickly as possible back to set point. If it doesn't have the switch, it will still alarm at a 150F drop in which the PID reads as the door being opened, so it does the same thing and heats as quickly as possible.would you explain? I don't understand.
