Hi all,
I've been lurking for two+ months here soaking up information like a sponge. I've read the count's usual post to new knife makers several times and think I have my head wrapped around the concept of making a knife enough to give it a go. I started by modifying CS Trail Hawks, but got sucked into this section quickly.
Over the last two days I layed out the design for and rough profiled a fillet knife and a bird & trout using .70" S-35VN. The fillet needs a bit more touch up, but the bird & trout came out pretty good. I'm currently waiting on a bubble jig to grind in the profiles.
So far I've picked up: several hand tools I was needing, a 2X42 craftsman grinder with a good selection of blaze ceramic and gator belts, 1084 & S-35VN from Aldo (best packaging of ANY package I have ever received!), several wood scales and I'll be ordering some micarta today, the misc epoxy, pins, sandpaper, and other disposable supplies typically suggested. I have a decent variable speed drill press that does it's job well.
Any suggestions for any other "must have" tools?
I would like to heat treat my blades myself, if for no other reason than because I hate waiting on shipping.
I've built a 2.5 brick forge based on the 2 brick forge WIP, but could only find hard firebrick locally.
I went ahead and completed the forge, lined it with approximately 1/8" of refractory cement. Last night when I fired it for the first time it did not appear that the heat was even or as hot as it should have been with propane. Switching to MAPP gas made no dicernable improvement. Does hard firebrick retain less heat than soft? Is there an easy solution for heating a small 2.5 brick forge better or more evenly? Better torch? More insulation? Second burner? More importantly am I chasing my tail building a forge when I would be better off purchasing a larger forge? (I was looking at the 2 burner deluxe knife making forge from Majestic Forge last night) The town I live in is about 50k people but sourcing forge materials seems diffcult.
I will also be ordering a PID with K-type thermocouple for temperature monitoring this weekend.
A big thanks to everyone so far for all the information contained here.
~Smitty
~Smitty
