The 50lb hammer will run at a 100% duty cycle with a 5HP 2-stage air compressor.
3800 for an iron kiss or 4000 for the KA75...... i'm thinkin iron kiss!
How much are we talking for a 5HP 2-Stage air compressor? How many gallon tank is needed? And what kind of juice/wiring is needed for that?
For something that power hungry I would recommend a reliable brand such as IR or Quincy as the top of my personal list. IR units of that size run $1000-2000 Quincys run $1200-1800 in the splash lubricated flavor, and far more in pressure lubricated.
Tank size doesn't matter, when you're pulling the amount of air that the pump produces the tank will draw down until and equilibrium is reached, larger tanks cycle on and off less often, but take longer to recycle.
60gallons or 80gallons is likely the size you'd be looking at for a 5HP unit. 120gallon tanks are common on larger 7.5HP and up compressors.
Usually they are rated at 220V 22A requiring 10AWG or better wiring. And a Dedicated breaker.
http://www.aircompressorsdirect.com/Quincy-2V41C60VC/p855.html Would be my first choice.
... You'll notice that the 50lb Iron Kiss has a 25:1 anvil:ram ratio....Pound per pound, they're cheaper than almost any other hammer on the market at less than $2.50 per pound of machine weight...-d
Hi D, I am already saving money for the 75lb, so give that one a work out too.
Dan Seaver said:If their $2.5 a pound then a 50lb hammer weights a bit over 1500lb, with a 25:1 anvil to ram ratio the anvil alone should weight 1250 or 20 to 1 would be 1000lb. Plus if the anvil is 7x7x36 it should weigh in at 499.21lb. Does he include the bolted on 7x7 behind the anvil and the base plate in the anvil weight?
I'm a loud mouthed opinionated Fairbanks hammer owner bastard
Edit- D, if your having trouble with under 1/2" with your press build a rolling mill. My hammer will hit as gentle as a kitten jumping on your lap and I've forged bars to .08", but its still not a replacement for a good rolling mill.
You got it Mike!
The foot plate does indeed count as part of the anvil weight. Don't forget though, I said "less than $2.50" per pound. I don't know the overall machine weight of the 50# off hand, but i'd be willing to bet it's on the lower end per pound.
Enjoy it! I can't seem to find a brand new Fairbanks anywhere though
It's definitely in the plans, but a better press than what I have and a bigger hammer than my Kerrihard are in the plans first. Priorities my friend, priorities! Whatever extra thickness may be left is fixed by the Blanchard grinder anyways
-d
Thanks for the quick and honest answer.
yes but the anyang has the number 33 on it and the Iron Kiss has the number 50.
kind of like on spinal tap with the amps that go to 11
It's just that simple. I mean, when the base plate is 24"x24"x2", it adds to the effective mass of the anvil by 324lbs. It's all just physics.
-d
