jdm61
itinerant metal pounder
- Aug 12, 2005
AARRRGGHHH!!!!! I bought a couple of blocks of VERY expensive presentation grade ironwood burl at Blade and was saving then up for a special project. I was putting one on a nice little bowie for the belgian show and as I ground the block, I noticed a couple of little "wormhole" type voids up by the guard. The deeper I ground, the worse it got. Turns out it was a void that went all the say thought the cneter of the block and was around 1/2' inch long by almost 3/8 tall and maybe 1/16 wide. It cut across the entire bottom of the handle and you could see the tang, so there was no way to fill it. The worse part is had I drilled the tang hole from the other end, it would have been okay because the block was 5 inches+ long and the handle only 4 1/4, so the void would have ground out......double AAARRRRGGGHHHH!!!!! $50 down the drain:grumpy:
