- Apr 24, 2013
food prep knives are think not for sharper cut but due too weight and allow thin slices not neccassary sharper edge. I am sure a good fighter is sharper, unless high japeese knife or similar, then my chicago hollow ground.
thickness is also from lazy knife makers who do not want too remove steel - lot blanks are heat treated before hand.
I listen too video from a $200 survival knife spam ad, the maker said it worked out better that way - o ya?
how many different types of heat treat did you try?
also they where using the latest fancy alloy from CPM, i have a lot respect for CPM, but not for knife makers where the easy method is the best method.
then again lets take you tube video craze, lets get ron hood knife heat it, plunge it in water, heat up then repeat, try to break it! no one would watch the video if we "did not break it" - we leave out the reverse heat treating.
thin or thick depends on the maker, better and more skilled the maker, the larger the r&d, the older the technolgy shoud say the more mature there skill and technolgy - better your trust the knife is made too its optimum thickness.
skill does not equal technolgy but go hand in hand - skilled samuri maker from 400 year old shop will make a think sharp blade. it would make good kitchen knife if cut down or good survival knife as was used in wwii
since orginal thread maker is happy - i leave this complex subject alon
thickness is not function of intended use it just is not that simple
