- Nov 5, 2016
For beginners i recomend 1095 its very easy to work with
My bad your right. I forget not everyone has propper tools or abilitues to do a good heat treat.Facepalm, no no no, blind leading the blind.
Don't use 1095, I really wish this absesion with it as a newb steel would end. It's not the steel you want or need, you need tough for a chopper. I'm Not saying 1095 is not a tough steel, it can be but its not the easiest steel to heat treat properly if your just starting out and have minimal tools and equipment. There are many choices in steel that can provide you with the desired results and are much easier to work with for people with no experance. Steels that come to mind are 1075, 1085, 5160, 80crv2.
Rule of thumb is stay with the Hypo-eutectoid steels, 0.8% carbon or less. The Hyper-eutectoid steels have between 0.8% and 2% carbon and become a bit trickier to heat treat properly.
With all this being said get yourself a stick of 5160 from New Jersey steel baron and update your profile and location so we can better help you on your path to being sescesfull.
I would like to see your 1095 knivesI never had any issues when starting out with 1095. Just saying
Um wow, thanks for the good laugh. Honestly don't start with CPM15, pricy and requires very precise heat treating in an oven.What about cpm154? Or is that too hard to treat too?
