The BK9 combat Bowie is 0.215" thick and weighs 530 grams. My SHBM is 0.275" thick and weighs 660 g, it is 1/16" thicker than the BK9. They both have full flat grinds on similar width blades and both have similar balance points, one inch infront of the guard.The Last Confederate said:Enough to drastically be noticable by the user?
Assuming the edge has an sensible profile for the task, if it doesn't then have the angle and relief adjusted to match your required scope of work.ERdept said:I want to know if it can cut something easily.
I have to agree with Cliff on the above statements. My main grind when making knives is the convex grind. I tell people looking for a convexed knife if you want the advantage of the convex grind but still want to slice then you need to go with thinner stock. I have had good results slicing with a convex grind using 1/8" stock or less. Also using 5/32" stock brought down to a zero edge works well for slicing. The 1/8" seems to be the best compromise.You will be giving up the ability to have lateral strength by going with thinner stock. The two pics show a 1/4" Steel Heart 5160 blade blank that I bought from Justin Gingrich and finished with my convex grind. It has a convex grind, full to the edge. A very very slight secondary bevel. Hardly noticeable. The other pic shows the edge. Sorry for the bad pic, it was tough to get a clear shot of the edge.Cliff Stamp said:It is 25% thicker than 1/4". A 1/4" blade is only 1/16" larger than a 3/16" blade. These can easily make large changes in blade stiffness, balance, and weight and are easily enough to effect cutting ability unless the geometry is adjusted.
[convex grinds]
Same as any other grind, the extent of the grind and specifically how the edge is tapered is critically important. Convex grinds don't have an advantage here, if anything it is easier with flat and then hollow because you can create a thinner profile on the same stock thickness.
There are also advantages to the really thick stock such as if you do a lot of thumb on spine grip work. Some people also like the feel of more weight in the handle, assuming a sensible balance.
The downside to thick stock is it needs thinner edges, thinner stock can leave thicker edges and get the same cutting ability and have vastly greater edge durability. But of course you lose prying ability and other features of the thick blade stock.
There are really no useless blade grinds, they just have the performance optomized for different tasks.
-Cliff
0.058" thick stock, full hard M2, ~65 HRC :Razorback - Knives said:I have had good results slicing with a convex grind using 1/8" stock or less.
This is a customer design and order. O1 was requested by the customer. I do not normally make knives thicker then 1/4". Talk about hogging off steel.the possum said:Razorback-
I was just a bit curious about the project you mentioned.
You said you're making a blade 5/16" thick from O-1. Why would you choose a steel that's not exactly known for toughness, on such a heavy-duty blade? Unless this is a wood working tool, where you just need the weight for momentum and the thickness for wedging, or something. ?
I appreciate the offer Cliff but I don't use 3V. I use 5160, O1, D2 and A2. The four steels I use I can heat treat. I have no experience with 3V. As far as the other requests, yes.ERdept said:How much is something like the pic above? Do you do 3V steel? In about a 9 inch blade that's starts off at 5/16 inch thickness, with G-10 handle and removable handle rivits, that's coated for rust protection, in a recurve style?
Potenial customer talkin now,
Cliff
ERdept said:1. Cool Factor. Just to have something different from most knives.
2. The weight of having a chunk of steel in your hands.
3. Prying strength. The very thing we were told to never do with a knife.
4. A lot of stock that can be ground down over and over for a lifetime.
All that aside, I want to know if it can cut something easily.![]()
The Last Confederate said:Realistically how much?
In real world proper knife use?
