Smoke, when I get a chance I'll try to do a better job and post a review in the Review forum or nonspecific one.
For the moment:
I will try and give a mini-review of the Busse Badger Attack. Perhaps when I get a chance to use it more I'll incorporate the following. First, the shape and heft is great. Feels good in hand. Probably, not the ultimate slicer because it is 1/4 inch Infi. It does taper quite a bit so it is manageable. If you do not mind a little extra weight, probably the perfect knife to carry for a hiker who is only going out for the day, but wants to be prepared for emergencies .... especially when combined with a saw etc. on a multitool.
It is heavy compared to a knife like the Spyderco Moran, but more readily carried than say a Battle Mistress. It depends on your knife using style. I cannot imagine being able to damage it past usefulness in a survival situation. Even Cliff would have to work at it.
If you are a knife, and saw or clipper, type person it is more than you would ever need, including long outings. For more civlilized locations you might get less unwanted attention, than if you carried your Battle Mistress. It is not the thin scalpel type knife. I is certainly OK for hunting, especially if your want to be aggresive in your use of the knife or if it is a tough animal...say a turtle. Since I do not hunt, I cannot give a better evaluation of that aspect.
It did not come, nor have I gotten it as sharp as I like. It slices paper, but will not adequately push cut it. Will shave, but not cleanly. In other words, it is not hair popping sharp. It has the now typical asymetrical edge. Tried it on my whittling stick, before the last sharpening attempt. OK. Tried my Small Sebenza which got bigger shavings. It is softish wood, but hardened with a few months of age.
Handle is extremely comfotable. Black Canvas Micarta, I assume. Would be great for cracking nuts with the butt of the handle.
Sheath-adequate. Can carry it with the belt through the loop and blade portion outside or inside your pants. Loop is screwed on and I have not managed to unscrew it. The strong (green?) Loctite???? ...or it was personally inspected and then screwed tighter by the
the hammer slamming steel sucker
himself.
Instructions: None.
Fit and finish including grind but not sharpness: very good
Overall evaluation:
out of a possible 5 large grins. Bottom line: I love it.
P.S. Some pictures here:
http://albums.photopoint.com/j/AlbumIndex?u=91257&a=817804
[This message has been edited by Donald (edited 02 December 1999).]
