- Apr 21, 2007
Let me use the term 'pure' rather than 'true.'
I believe most would say a pure ("real"...whatever...) Scandi grind is saber flat zero ground...no secondary.
At one time they were likely sabre hollow ground as only big wheels were available to grind them. Modern day, however, the real Scandis are zero ground to the edge from the beginning of the upper grind.As far as the subject here, the grind differences, maybe if I put it this way: A pure Scandi is always a sabre but a sabre isn't always a Scandi.
A good point you make is that most people probably term it more by the look of the knife rather than such technicalities as we're getting into here. Your point is valid. I would call anything that looked sabre zero ground a "Scandi," even though it may have secondaries or micro bevels or hollows I can't see at the time without my loupe.We're already on ground that is way too technical and wouldn't even be noticed by most users of the knives. I'm speaking strictly about the definition of the grind itself--Scandi.
We need to hear from the knife makers...which I am NOT. I'd be glad to receive further education on the subject.
EDIT: I'll also say, in consideration of the history of the blade design way up there in the north....a zero grind makes for easier sharpening which I think would have been a consideration back then. Example would be the leukus with that grind, developed by the Samis.
Looking at photos of antique stouraniiphi / leuku from a museum here in Stockholm, shows convex edges.
Looking at a1200 years old knife in another museum, has also showed convex scandi edge.
The flat or hollow zerogrind edge is used on today's industrially produced blades like a Mora.
Many custommakers here, use a hollow grind with a bevel, that sometimes is convexed.
The term Scandigrind is an American or English definition.
A flat zerogrind is used for detailed cuts, when woodcarving or light work when trimming off very small pieces.
Tougher work needs a bevel or a convexed edge.
Regards
Mikael
