Micarta doesn;t really need a wax or sealant. Other posters to this thread have already said, and I agree. I recently took a detour from wood and began scaling knives with Micarta. Here's why it needs no sealer:
Micarta is layer upon layer of paper, linen, canvas, burlap, etc,. Each layer is soaked in an epoxy or other fiberglass resin (epoxy, for all intents and purposes) before being aligned and pressed to dry. As someone said earlier, if you sand Micarta and leave the first layer (or layers if sanded at an angle, as in knife scales) exposed, it still has the epoxy resin imbedded in it. If you feel the linen, for example, of that exposed layer, you're only feeling the very surface. Just thousandths of an inch down, you'll hit epoxy.
If a guy wants smooth, unexposed Micarta, he can sand the scales to shape with finer and finer grits of sandpaper (I stop at 280). Then, using a charged buffing wheel, buff the scales. When finished, they'll look and feel varnished or wax-coated, though they're not.
The reason I say don;t put it in the dishwasher is because it can free the epoxy bond between Micarta and knife blade. I doubt seriously if it would affect the epoxy embedded in the Micarta, though obviously I haven;t the experience of testing this. Maybe if you put some Micarta in boiling water, over a period of time it might break down. A theory based on my limited knowledge of Micarta and logic is all that is.
Here is a Micarta-scaled knife that has been sanded to 80 grit.... just getting started on it. But...if you look at the end of the scales, up front where scales meets blade, you can see where I've sanded and polished the Micarta before glue-up. I do that because it's the area of the scale that really can't be reached
after glue-up, so it must be done before. The actual knife is completed now, but I don;t have pictures yet. The point is, only sanding and buffing is required to produce a smooth, shiny surface.
Here is a picture as the Micarta arrives from the dealer. It's surface has been sanded and buffed. I don;t believe there is any type of finish on it other than maybe leftover buffing compound embedded in the pores...maybe.
I have shellaced and waxed Micarta before. I made an Enzo knife (kit) with green
canvas Micarta. I didn;t know much about working with Micarta at the time, so I figured I'd better "seal" it. So shellac and wax I did. Now I realize that was completely unnecessary.
