Having had both and liked both, I cans ay that both are good cutlery steels. But, they are different creatures. You really can;t compare characteristics of a carbon steel at a higher RC to a milder stainless steel. It's apples and oranges. Buty I can tell you that true sharp does way better with a coarser edge on it than you would put on a CV blade.
I think I've lived long enough to finally draw some conclusions from all the mistakes I've made, and one is, don't get carried away sharpening a stainless blade in the milder steels like the true shape from Case, Whatever Victorinox uses in their SAK's, and other stales blades that may be in the mid 50's range. For them, I found out quite accidentally that the edge I got off ann old "carborunum" stone, what is now called a silica carbide stone, actually lasts very noticeably longer under "hard use" (yeah, I actually used that term, I'm going to self flog myself right after typing this) like slicing cardboard while breaking down boxes for the recycle bin. I can't explain in technical jargon, but I just noticed that the old toothy course edge off an old Norton economy stone or my old boy scout stone I found in the attic, does a better job on mild stainless blades in the RC55 range.
Try putting a bit courser edge on the true sharp, and you may get a surprise on how much longer it cuts before needing a touch up. Coffee mugs work well too, but don't use too fine a grit bottom.
