Is halving a chicken knife abuse?
Here's my definition of "knife abuse"- If you use a knife in a manner that you know, or should have reasonably known, would ruin it, that is abuse.
Anything else is just "use".
I say, if a knife can perform a task without being ruined, and without causing unwanted damage to the item/material it is being used on, and if that knife performs that task well, then I consider that knife to be well suited for that task.
I'm 45 years old, and I have never been issued any "Knife Bible", or any stone tablets displaying the "Ten Knife Commandments", or any mandatory "Knife Rule Book", to tell me what a knife should or should not be used for. I decide for myself what MY KNIVES should and should not be used for, and I don't let anyone else make such decisions for me. And neither did my father, or his father before him.
I say- use your knives according to your own needs, and follow your own judgement in doing so. And don't let anybody, not even the self-anointed "Knife Authorities" out there, tell you any different.
I use my Griptilian in the kitchen everyday, and I've successfully cut up numerous chickens with it. The serrations are great for the stubborn parts...
Best tool for the job? Maybe not. But it's the most fun tool that's for sure
I can see not wanting to do it with a gyuto. But in general what rules should we follow. What steels are inappropriate and what steels are appropriate, or is it more a question of edge geometry and thickness of the blade?
More geometry than steel. Almost any outdoors blade and most modern folders will cut raw chicken bones without any damage. Honestly, most kitchen cutlery will do the same. Problems start to come up if you're using blades that are ground very thin and really optimized for slicing. A proper cleaver will give you the best results, but don't worry too much about damage unless you have some very, very lean grinds in your collection.
Opinel # 10. It's a farm knife. :)
Any good hunting knife. That's the kind of work they're designed for. Folders are fun, but harder to clean.
I used to make do with poultry shears, and they actually work fine. It is faster and neater to cut up a chicken with a Tojiro Western Deba. It is like a heavyweight Gyoto or chef's knife, but can work like a cleaver on chicken.
Some of these threads are ridiculous, like this one. People that ask questions like this clearly have not used knives much at all, or quality knives much at all.
If halving a chicken harms your knife in ANY WAY, you need to throw that piece of junk in the garbage. Simple as that. Halving a chicken like what was demonstrated in the video is NOT EVEN CLOSE to abuse. This is what knives are made for people. Geez
OP I guess every hunter that has cut through a ribcage or pelvic bone on deer, moose, or elk need to throw their knives away. Give me a break. I guess you are seeking knowledge tho, which is apparently needed
Instead of using a folder for the wrong job why not let your love for knives send you to a cooking store (William Sonoma, Sur La Table etc.) and buy a few kitchen knives.
Victorinox makes some great pairing and Chef's knives. Get a 6" Chef's knife for your chickens. You don't need a lot of knives for basic kitchen work but you will immediately see the difference between using a Spyderco folder (the make some kitchen knives too) and a proper Chef's knife. For tougher tasks you may want a cleaver but my 6" and 8" Chef's knives can handle most jobs in my kitchen.
Can I use a hand trowel to dig a fence post? Maybe but why not use a post hole digger? similar logic applies.
If you think that, you don't know as much about knives as you assume. Anyone who tries to use my gyuto to chop through chicken bone will get physically tossed out of my kitchen. A knife is a balance of resiliency and efficiency. High end kitchen cutlery often forgoes resiliency to maximize cutting efficiency, making it perfect for chopping veggies or slicing protein, but totally unsuitable for chopping chicken bones.
First of all I would really like to think TBL and Lance23 for posting pictures of their knives in use.
Ok. So I was not looking for a knife bible. But it occurred to me that a Phil Wilson Southfork in CPM 10V might chip under this use. But then again I never use CPM 10V and started to wonder what knife steels/geometries are too fragile for this task. Thank you for sharing your anti-authoritarian wisdom with me, I learned nothing from your post.
Thanks a lot Insipid Moniker. Sounds like the A1 or similar knife will do just fine. I really appreciate your reply as it has taught me something.
I do have an opinel. It is ground VERY thin and very sharp. But it is so cheap and easy to grind that I am not afraid to chip it. I might just try it and record its sharpness before and after. Also will see if any chips occur.
Ok. Sadly I am getting the feeling that Karambit is saying what a lot of others are thinking. I really don't understand what part of my question made me come off as a six-year-old-spoiled-brat-jerk-script-kiddie. Do I have to apologize that I can't cook? Or should I apologize for wanting to learn how to properly use a knife and what knifes are appropriate for a particular task? I don't get it. So Karambit: please enlighten me as to how my post offended you to the degree that you felt it was necessary to reply with such a sour attitude instead of sharing your obviously infinite well of wisdom with a young man wanting to learn.
Insipid Moniker, could you give any guidelines as to when a knife is appropriate for cutting a chicken in half and when it is not? In general I think I fully agree, some blades will half a chicken without damage and others are optimized for slicing making them too fragile. But I don't have enough experience to make that call as to what knife needs to stay away from these types of tasks and what knife is well suited for it.
In closing, I want to clarify a couple of things:
1. I was not calling halving a chicken knife abuse. I was asking if it was.
2. If it is not knife abuse in general what type of blade is appropriately suited for the task? Is it a question of steel, temper, and/or geometry?
Did I ask this question because I want to enjoy my blades in the kitchen? Yes. Is that a little bit silly? Maybe. I am sure sheers are easier, but like many said that takes the fun out of it. Is it a stupid question? No. The A1 is billed as a survival blade and I see no better way to practice using it then to use it on a chicken and other tasks around the kitchen. After-all when surviving you might find that you have to prepare food. Possibly a chicken-like bird, who knows.
Anyways, I am somewhat shocked at the attitude. If this is not a forum to learn from peers then please let me know. In general I have learned allot from bladeforums and I am very thankful for it, if this is not a place for newcomers to ask questions then please make that a known policy.
- T
- T
Don't feel bad...some folks around here can just be grumpy jerks is all. ;)
Any knife that even remotely resembles a "survival knife" will have no issues cutting up chickens.
Just don't use a straight razor--or knives whose edges closely resemble one--to chop bones, and you should be fine. :thumbup:
Honestly, most of the knives that aren't appropriate will come with packaging telling you not to do it. As a general rule of thumb, Japanese gyutos, French chef knives and Chinese veggie cleavers should steer clear of bone. German chef knives, meat cleavers and debas, have at it.
If it's a knife you would use to carve wood, raw chicken bone is unlikely to hurt it, so go for it.
As is frequently the case, Stabman gets the point across in many fewer words than I use. ;) This guy knows what he's talking about and I agree.
Thanks and thanks. Time to go have some fun in the kitchen.
It can be done with a shrapened rock, but these are pretty efficient if you have a bunch to do:
If your Gyuto cant handle processing chickens in the kitchen (although it most assuredly will) then you have a lemon that was ground way to thin. I agree that there are certain knives designed for certain tasks, however simply processing chickens should not harm any knife or blade grind. Im just saying that processing chickens like the video demonstrated was nothing abusive at all. ZERO for any knife. A quality kitchen knife is designed for that. a "Chefs" knife design is made to handle almost everytask including processing proteins, or veggies. Yes a Boning knife is optimal for processing whole game, but they all can do it, no luck required.
