With the motor running disconnect the negative post,if she keeps running it's the battery.How to determine???
That might work on cars up until the late 70s past that I'd be careful, as computers became more prevalent in the 80s disconnectin' the battery while the car's runnin' could become expensive as you star fryin' computer modules.
disconnecting the battery does effect sensors, so dont do it if your about to get an emissions test, other than that it just resets things so you good to go. The car only uses the battery to start, after starting the alternator takes over which converts mechanical energy into electrical energy. So if your car wont start, try a jump/charge, if the cars jumps and stays running (without dimming lights, lower radio volume, etc) its your battery. If the electrical equipment is failing while the car is already on, its your alternator.
Click on the followin' link and read about disconnectin' your battery while the engine is runnin'.
http://www.aa1car.com/library/battery_disconnect_problems.htm
The issues it creates by resetting sensors, modules and other computer controlled components is just not worth it, unless you're knowledgeable in the field it's just better to take it to car quest auto zone or any number of auto parts stores that offer diagnostic services, usually for free.
