- Jul 13, 2009
So it will fire up and run but it wants to and does stall unless I keep my left foot on the brake pedal and light pressure on the accelerator.
Standing voltage is ~ 12.2. It dips to about 11 when I fire it but quickly winds up at ~13.5.
The dip is what's causing it to stall.
Now the check engine light is on so I need to pull the codes and figure out what TF that's all about also. :grumpy: Replacing the alternator is a nightmare in this model so I am hoping to avoid. :grumpy:
It may also be a constant drain that is not being turned off with the key.
I had this trouble & some electrical module needed replacement.
