- Dec 26, 2012
First, a little backstory. I recently sold a very well constructed new-in-box midtech on the secondary market. Same day that the buyer received the knife they said they would have to return it due to "lock-rock".
I'm familiar with lock-rock. With the knife open and locked, the blade will have movement about the vertical axis. It's very annoying and the lock-up will feel anything but solid. The movement between the blade tang and lock-bar contact surfaces can be easily felt. I knew that I would have noticed lock-rock but agreed to refund the buyer and have the knife returned.
Upon getting the knife back it was clear that there was absolutely no lock-rock. I was, however, able to get the lock bar to move outwardly to the side when firmly holding the knife handle and putting a considerable amount of force against the spine while the knife was open. Under this kind of stress there is lock-bar movement and a slight lock-rock but in what reasonable"real-world" condition would there be force against the spine? I guess I just fail to see how under normal use this would even become a problem.
To sum it up: How does the lock-slip test, of putting pressure on the spine of an open frame-lock, really translate into actual use? Is outward lock-bar movement under considerable blade spine pressure a reasonable indicator of future outward lock-up failure? Apart from batoning a folding knife, in what situation would the spine of the blade even be exposed to such a force?
