- Sep 19, 2011
A few days ago my KMG was hogging materials. I could run my VFD at 10% with plenty of torque left to do anything I wanted and anywhere above 10% with power to hog material. Below 10%, the grinder has always vibrated a lot and just really not performed well, so I've considered 10% to be the bottom setting for my uses.
Now, the 2HP Leeson motor is running in forward and reverse. Regardless of speed, there is very, very little torque. If I put my flat platen on sometimes it will start to move the belt and sometimes it will stall before moving the belt. When it does move the belt, after a while the motor will stall just from the friction of the belt on the platen. With the belt over wheels it runs until you make contact with the belt and then stalls again.
As long as you don't make the motor stall, both lights remain green as they should. After stalling the motor, the bottom light blinks red. The only way to "reset it" and make the grinder run again is to switch the VFD power switch off and back on. Just flipping the motor power switch doesn't work.
I have a couple short videos on my instagram as g_polk_knives if you care to take a look there.
Is my motor dying or do you think something else may be wrong? Clearly something isn't right.
