LRB has the answer.
Adjust the forge to run efficiently with a neutral atmosphere, and coat the bale to prevent oxidation.
There are dozens of products and methods to coat a blade, but they all do the same thing .... keep the oxygen away from the steel surface. A thin wash of ATP/satanite/Brownell's PBC/clay/etc will also help with more even heating of the blade.
Now, about O-1 as a beginners steel.
It used to be recommended as a good beginners steel often....because it was readily available. That has changes with the availability of many types of blade steels from all the suppliers today. The interconnected world of today makes availability only a few keystrokes away from any product you need, and accessibility is only as far away as your mail box.
O-1 is ( very basically) iron plus 1% carbon, with chromium, tungsten, and nickel added. This gives it some advantages in certain abilities. It does not make it a superior steel, but a properly heat treated O-1 blade will be a very good knife (with the proper blade geometry). However, the extra alloy ingredients need to get into solution. This requires holding the blade at a fairly steady temperature of 1475°F for about ten minutes. Most forges just are not capable of holding that temp evenly for any length of time. A new maker will not know how to tell the blade temperature well, and will almost surely overheat the blade in attempting to keep the blade hot for even one minute ( much worse for ten!). A thermocouple in the forge will help only a little bit, as the blade may be heated much higher by the flames than the TC indicates.
The answer is to use a similar steel without the alloy ingredients....one that will not need a soak time.
To the rescue comes 1084. This steel is called the eutectoid. That funny word means it has exactly the amount of carbon needed to bind up with the iron - No more, No less. It also has no other major alloy ingredients ( besides the necessary Mn and Si needed to make steel). This means that the blade only needs to be heated to about 100°F above the transformation point ( the temperature where the structure changes to austenite - AKA, critical temperature - around 1350-1360°F) to get all the carbon tied up with all the iron in a way that will lead to a good knife. Once the 1084 blade gets to around 1450-1500°F, you quench it immediately in a medium-fast speed oil. Canola oil from the grocery store will work fine. The temperatures can vary as much as 50°F without ruining the HT, the quench isn't super critical, and you don't have to hold it at the target temperature any amount of time. There is no steel simpler or easier to HT. The final result is a 100% martensite blade with great hardness and toughness.
A properly hardened 1084 blade will hold its own against any carbon steel knife blade. I regularly state that a 1084 blade with a good HT will beat any blade having a so-so HT on a "better" steel. To re-state that in a different manner - Good steel will not make up for bad HT.
Many makers are returning to 1084 for making high quality hunting and kitchen knives.
The newer 1084 alloys add a touch of any or all of these - vanadium , tungsten, nickel, chromium.
Just enough to make the steel forge better, but not enough to make the HT any more difficult. These alloys are often called 1084FG, 1084+, and similar names. Most of these are also slightly higher in carbon content to allow for some loss in forging. This is what is currently being sold by the knife suppliers.
1084 is a very good starter steel...and a very good advanced skills steel.
