Is over heating before hardening and tempering an issue?
When I am shaping, and grinding the bevels before heat treat, is over heating an issue? I know after the temper, when finish grinding and polishing, over heat will ruin it, but won't the straw and blue color I get while rough shaping be canceled out by the red hot it becomes for hardening?
Yes, that's right, you should be fine. Overheating while grinding can lead to stress that contribute to warping during HT, but not just drawing straw and blue. I think you gotta get it glowing red to create issues.
I've been told by my HT guy and several makers here that's it's fairly difficult to really screw up your steel by grinding heat pre-HT, and (depending on steel type) the ramp-up to austenizing temp and subsequent soak will usually even everything out. If you're really concerned, you could do a normalizing cycle before HT to be sure.
As stock-removal makers, what we think of as aggressive grinding, "high" heat and stresses doesn't hold a candle to what forgers put their steel through. Makers who forge routinely do a normalizing cycle or two before hardening.
