Hi Stitchawl,
Thanks! And lol @ some of your magazine "studies."
If you were to get a strop today, which specific strop would you buy, and/or which strop do you use these days?
If I were buying a strop, I'd ask myself a few questions first;
1.Is it going to be used on a straight razor, knife, or carving chisels?
2.Do I want the edge to be beveled or convex?
If I were working with woodworking chisels, I'd use an MDF board with Chromium Oxide on it, not bothering with any leather. Obviously, any smooth, flat, hard surface will do for this, but it does need to be hard.
If buying (and I stress the word
'buying,') a strop for knives, ordering over the Internet, that I was going to cover with compounds, I'd look for a single sided block mounted piece of cowhide, smooth side up and un-sanded, at the cheapest price I could find. Smooth side up and firm for beveled edges, but rough side up or sanded and less firm for convex edges.
But I wouldn't buy one... If I have to order something, I'd order a 12"x12" piece of tooling cowhide for knife sheaths from any of the knifemaker supply sources (I'd really prefer horsehide, but that's often hard to find and if your going to cover it with compound anyway it doesn't make a difference,) for $10-$15 and cut it down into four 3" wide strops. $2 worth of glue and some free scraps of wood from the home center or lumber yard, and I'd have four different bench mounted strops that are as good as anything you can buy on the Internet. If you really want even BETTER strops, spend an hour or two rolling dampened leather with a heavy rolling pin to compress it, then let it dry and glue it to the blocks. No special tools needed to make it unless you wish to do some creative wood working for the base. Your EDC should be more than sharp enough to cut the leather. If not, you don't need a strop yet.
If my purpose is a strop for a
straight razor, if I could afford one made with horsehide, I'd pick the prettiest 3" wide
hanging strop, from which ever
'SHAVING' supplies company was selling it. If cost was an issue, I'd pick a 3" wide hanging cowhide strop. Again, from a SHAVING supplies company. I'd chose one that had a brass swivel on top, and something to hold onto at the bottom. I would
NOT be swayed by claims of Russian Leather at much higher prices unless it was horsehide. If I could find a horsehide strop made from shell cordovan, I'd buy that in a minute! Razor strops aren't magic things. They are tools to be used daily, so should be well constructed and be comfortable to use; i.e. good handle and good swivel hanger. But if you read the various shaving supply sources, most don't even bother to say how thick their leather is, or from what part of the hide it's coming from, how it is processed, etc. Most just say 'premium leather' or 'top grade cowhide,' neither of which has any meaning in the leather trade... So don't waste money buying the most expensive available. It's not necessarily the best to use.
I have a closet full of old HandAmerican strops that never get used. Probably a dozen of 'em now as I've given away so many over the years. I've my Grandfathers real Russian Leather horsehide hanging strop that I look at more than use. Then I've got a couple of 3"x 10" cowhide strops that I made, just cased, compressed, and glued to a piece of 1x3 scrap pine. I put some 2.5mic Silicon Carbide paste on one, 1.8 diamond paste on another, .5 mic Chromium Oxide on a third, and .25 mic Diamond paste the fourth. Of them all, I really only use the .5mic Chromium Oxide and the .25mic diamond, and then go to a 3"x10 block mounted shell cordovan horsehide strop that I made. I also have a piece of 3x5 unmounted shell cordovan horsehide that sits in my pack for travel.
Basically, after using my EdgePro and polishing tapes, I might use the Chromium Oxide and the bare horsehide more than anything else, and I only need the EdgePro 2-3 times a year. My kitchen knives don't get stropped, but they do get touched up every week on a Sharpmaker, and 'steeled' (with a borosilicate glass rod) before each use daily.
Stitchawl
