I managed to keep it shaving sharp using a Sharpmaker about once a week, and didnt go back to the sander for about 4 months. The trick is to sharpen at an angle about 5 degrees less per side than the touch up angle. This reduces steel removal to a minimum, and the narrow, higher angle bevel doesnt reduce cutting enough for me to notice.
Once a knife gets to the point of shaving sharp, can clean the hair off of your forearms for example, is there a need to try to sharpen further?
So is your primary bevel closer to 10 or 15 degrees per side?
I don't think so, unless you want to get it to "clean the hair off your face", in which case you risk getting an edge that will chip very easily.
Best,
Edalb
I think it depends on what you are planning on slicing. You going to be sawing vines off the roller of the chipper, or are you going to slice up milk bottles or cardboard? Maybe just open an envelope? As someone alluded, really ultra-sharp blades can be fragile as a consequence of being too thin for the job at hand. Don't believe it? Slice/whittle a few bottle corks with a straight razor. Look at the nicks in the blade. Now try it with your hunting knife. What's the difference?
For me personally, there are times when less than shaving sharp is good enough. For beaters and especially knives that I am not the primary user of, I can put a "working edge" on one in well under a minute and I often stop there and call it good enough. These might just barely shave a little bit, but not well. Why bother to invest my time putting a really nice edge on a knife that will be immediately used to cut on glass or ceramic and then tossed into a sink? I call it quick and dirty sharpening and there is definitely a place for it.
I would be willing to bet that even for the sharpening fanatics, if they own a working axe, a splitting wedge, utility scissors or a lawnmower blade, these things are not hair whittling sharp or even shaving sharp even though they would work better if they were. Everyone draws the line somewhere.
Could you elaborate? I've never noted an inclination for very, very sharp edges to chip more than somewhat sharp edges.
The thinner the edge the easier it is for it to chip or roll. Take a hatchet and a straight razor for instance, If you take a few swings at concrete with each, the straight razor will be totally destroyed but the hatchet will have just a little chipping or rolling.
Edit: I don't know about your fiskars though.
It all depends on what you define "shaving sharp" and "sharp" as. If you define "sharp" as cutting ability, and associate "shaving sharp" as polished edges only, then the question is about two different qualities. Some will also associate "shaving sharp" as a thin edge, further muddying the water.
I do not think I would try to shave with any 320 grit edge, even if it did slice like the dickens, because those big microteeth are going to be ripping through the skin on my chin.But I would give it a shot with a chisel edge at a 45 degree angle, if it was sharp enough.
To go beyond shaving sharp - whittling hair sharp you need piece of leather on wood (few bucks), Green Rouge around $7 and less then 5 minutes. Why not to make it? Really, why?
