- Jun 4, 2010
Depends: For my work knife, sharp enough to easily slice through two layers of brown paper wrapper about 30 inches long. I open around 24 to 30 bags per 12 hour shift...thank goodness today is my last 12 as business demand just isn't there, back to 8's woohoo...if the knife is dull it tears rather than slices and can take several times as long to perform this task...I don't have the time to waste nor the patience trying to get a dull knife to cut through the wrapper.
I could achieve similar results using a stone of similar abrasive/polishing grit but my strop sits in the drawer of my side table aside my couch. I easily pull it out while watching TV...a couple minutes of passes and voila restored to sharpness for my next day of work.
For my EDC/hiking knives: They can shave the hair off of my arm and/or easily slice, without grabbing, through telephone book paper cut into 3x5 inch pieces...for ease of testing.
I've recently started using black compound and am surprised by how this compound improves the edge while stropping. I usually used just green...knowing it is more polish than abrasive. After reading much on forums regarding black compound I bought a stick at Sears for 3 bucks and used it on the untreated side of my two sided strop. Wow what a difference it makes. It does add sharpness and has really made touching up an edge much better, especially my work knife.
I added this compound after buying a Bark River DPH, which has a convex grind. In previous posts I talked about adding a bevel as I was worried about maintaining the convex edge...my stropping skills were not that good and I would dull a freshly sharpened knife about half the time when stropping with only green compound.
I took the time, after reading some forum replies, etc., to practice my technique and the improvement has been significant. I can now, with care and patience, improve the quality of a hone sharpened knife to a decent degree using the strop as a finishing mode. I can also quickly restore a knife that has dulled just a bit with a couple of minutes using the black then green compounds.
Here are a couple of pics of my "work" knife. You can see my thumb mark where I hold the knife during use. The material is very abrasive as it is a filtering medium for our water treatment system.
This knife: BM H&K Plan D is only several months old and used only for work cutting open the bags I described earlier.
A couple of quick thoughts that came to mind reading this ^. For a fairly rough use knife, that thing looks to have had very little steel removed in the course of maintenance. This in my experience is much more easily accomplished with a strop of some sort.
The Sears black works surprisingly well on its own and can often set up an edge for a finer strop if not too much repair is needed - have been a fan of that stuff for a number of years. Dico also makes an excellent black compound in the same range.
Attempting to maintain a regularly used edge with too fine a compound can often lead to a bit of frustration, and this is where stropping in general probably gets the most well deserved criticism. The smaller abrasive cannot remove enough steel at moderate to light pressure to restore many edges after use, and many don't bother with enough experimentation to find what works.
Initially I wanted to supply my Washboard with two compounds, Dico black and Flexcut gold. I split the difference and came up with my own multigrit formula that works fairly aggressively straight up, but if you wipe it down hard with a paper towel, it embeds the finer particles and some of the binder into the paper and makes a finer stropping surface - two for one. Its the ability to really tailor my results that drew me to experiment with stropping and lapping so much. My 10" Chef's knife was starting to loose a step in the kitchen, so before making dinner I pulled out my block and gave it four or five good passes with the finer abrasive level. For a test, it passed through a paper napkin with a shearing cut like it was a piece of newspaper - took about 20-30 seconds. Not that it was dull to start, but it got considerably sharper. It would have been a lot more demanding (for me) to touch it up with a stone.
I understand some of the reticence to bother with stropping - there was a time I swore it off too (in fact I still won't strop on leather anymore), but has become a mainstay of my maintenance scheme.
