What type of knife was it?
I am sure if you explain your honest mistake there would be no charge/fine and they'd just send it back.
http://www.austlii.edu.au/au/legis/wa/consol_reg/wr1999216/
For your info:
Item
Article
Description
1.
Acoustic shock weapon
An article made or modified to be used to emit sound so as to injure or disable a person.
2.
Ballistic knife
An article made or modified to be used to discharge a knife and includes the knife.
3.
Blow pipe
An article made or modified to be used to discharge a missile by air expelled from the mouth and includes the missile.
4.
Butterfly knife
A knife —
(a) having a 2 piece handle which folds together to cover both edges of the blade; and
(b) made or modified to be used to injure or disable a person or as a martial arts weapon,
and includes the martial arts weapon known as the butterfly knife or balisong.
5.
Catapult (with an arm brace)
A catapult made or modified to be used with an arm brace that fits or rests on the forearm to support the wrist from the tension of the elastic material used to discharge the missile (e.g. the article commonly known as the “Saunders Falcon Hunting Sling”
6.
Commercially produced catapult (without an arm brace)
A catapult —
(a) made or modified to be used without the arm brace referred to in item 5; and
(b) made for commercial distribution.
7A.
Crossbow
An article made or modified to be used with one or 2 hands to discharge a missile by an elastic force across a stock grooved to direct the missile and includes the missile.
7.
Disguised knife or sword
A knife or sword disguised as part of another article and includes —
(a) a knife disguised as part of a belt (e.g. the article commonly known as the “Bowen” knife belt); or
(b) a sword disguised as a cane or stick.
8.
Electric shock weapon
An article made or modified to be used to discharge an electric current so as to injure or disable a person but does not include an approved electric shock case.
9.
Electromagnetic weapon
An article made or modified to be used to emit electromagnetic radiation so as to injure or disable a person.
10.
Extendable baton
A baton made or modified so that the length of the baton extends by gravity or centrifugal force or by any pressure applied to a button, spring or device in or attached to the handle of the baton.
11.
Flick knife or Switchblade
A knife —
(a) having a blade that is concealed when folded or recessed into the handle and that opens by gravity or centrifugal force or by any pressure applied to a button, spring or device in or attached to the handle of the knife; and
(b) made or modified to be used to injure or disable a person or as a martial arts weapon.
11A.
Gas dart
A device designed or adapted to kill or injure an animal by injecting a gas into the body of the animal (including a “Gas Dart”, “Farallon Shark Dart” or similar device).
12.
Knuckle dusters
An article made or modified to be worn across the knuckles of a hand so as —
(a) to increase the force at the point of impact of a punch or blow when striking another with those knuckles; or
(b) to protect the knuckles from injury when striking another with those knuckles.
13.
Knuckle knife
A knife made or modified to be held so that the blade protrudes between the knuckles or fingers of a hand (e.g. the article commonly known as the “Urban Pal” knife).
[14. deleted]
15.
Spray weapon
(not oleoresin capsicum)
A spray weapon made or modified to be used to discharge a substance other than oleoresin capsicum.
