- Jun 19, 2006
All I remember was that this knife was supposed to have 3V and a compression lock. Would love to see it get made.
10V isn't any tougher than D2, S30V, S90V, or ATS34. 3V approaches shock steels in impact resistance, and M4 is tougher than those other steels as well. I would like a 10V folder, but not named 'Tuff'.
Phil Wilson Does Josh. He doesn't make folders though. I don't know of any custom folders regularly made with 10v/A11( same steel, different maker)
Phil's page with blade steel explanation: http://www.seamountknifeworks.com/about.htm
I agree, pivot pins and locks are failure points, and you can't swing a folder all that hard as compared to a huge chopper. Just trying to stick with the nameBasically I recommend it because of what Joe just said. Tons of wear resistance and insane edge retention. For a folder I would prefer the edge retention over the pure toughness because in all likelihood, something is going to break before the blade does.
Joe's idea for 10V in a sprint Stretch model is awesome though.
Does anyone know custom makers who use 10V regularly? I'm looking for a particular blade....
The idea behind the Tuff is durability. This knife will take extreme use. It will be the heaviest compression lock that to my knowledge that Spyderco has made. The blade is fullered for stiffness and reduction of weight. The thickness of the blade below the fuller was full thickness of the steel. It was designed as a 3/16 blade but might come to market at 4 mm.
Charpy numbers on 3V are extremely good and that criteria weighed heavily on the choice of steel...Take Care...Ed
