Fvdk, have you tried the KME? I'm wondering if I could get your thoughts in comparing both systems... there's not much on KME vs Wicked edge
I wish I would have given the KME system a closer look. Looks like a very competent design. I'm curious mostly about the blade clamping system.
Holy hell you got quite the Arsenal there.Let's just say that there are not that many systems that I do not have or have tried
I like the KME, it is a very nice system at an (in my opinion) affordable price. It will handle most knives and Ron's customer service is top notch so I can certainly recommend it.
It has a permanent place on my work table and I use it a lot. I would say that the standard KME diamond kit ($179.95) is functionally more or less comparable to the basic Wicked Edge system ($299.-)
The Wicked Edge Pro Pack II with all the extra accessories that I have like the extra ceramic stones, 3micron diamond stones, glass blanks, strops, and diamond films/sprays is well over $1000,- so it would not be fair to compare it to the KME.
Both systems will get your knives very very sharp but even with my Lansky systems I can get my knives sharper than I would ever realistically need. If you know the basic principles of sharpening and how to use the different systems, it is more about personal preferences, how much you want to spend, how much time you want to spend etc....
Personally I have a preference for the WE because of the build quality, versatility and the way it works (using both hands)
There is one very distinct difference between the KME and many of the other systems. That is, because of the swivel, you can work both sides of the knife with your dominant hand. This allows better control (for me), especially for very light touch fine tuning. At least as far as my personal coordination.
Granted with a little practice, this may be a non-issue. But for me it was actually a steep learning curve, especially on the EP. And I still think it affects some of the fine tuning on my EP. With the KME, it's a non-issue right out of the box. But if I try fvdk's EP magnet trick, it may become less of an issue. One of my biggest trip ups, was the fact that a lot of pressure needs to be added to the blade to keep it in place. And very light pressure on the stone arm for actual work. Then reversed when knife is flipped.
Which one has more repeatability? Also, which one is less likely to scratch up the blade? My biggest complaint of the kme is my scratched up blades...![]()
... And sometimes I get a little in to it and end up pulling the rod out of the eyelet on the down stroke...
I couldn't be happier with my WE. I can make edges that can cut through space and time itself. Zero complaints, and I've gotten to the point where it's VERY repeatable and very quick. I bought the gen3 system, with pretty much all the stones and strops and yes it hurt ($$), but it's a lifetime tool.
fvdk- I've literally lost my mind deciding which system and looks like you are my savior.... congratulations
Bought an EP Apex 4, but haven't used it yet bc unsure and want to be able to return it. Considering everything you have, but really focusing on powered options either as stand alone or to compliment a stone system.
Would you recommend Tormek T4 w knife jig(s)+ EP or KME? Does your Tormek see a lot of action sharpening knives? Where do you rank it against EP/KME/WE?
Really appreciate any feedback. Thanks
