My embarrassing grinder story.
I have had a 2hp step pulley kmg for over five years. I make fairly large chef knives and do alot of flat grinding on them. Due to the blade being two inches wide, there is quite a bit of surface area in contact with the blade and the grinder was bogging down regularly, to the point that I had to reduce the pressure I used while grinding. I decided to make a grinder that would not bog down. I went with a 3hp 3400rpm motor with vfd on a little buddy frame which is direct drive and also a 6inch drive wheel. This thing is a grinding beast and can go very fast. I tried all kinds of things to get it to bog down with no avail, no slowing this thing down. During the build I happened to retighten the belt on the kmg by sliding the motor back about a half inch and tightening it. I did a side by side comparison and the kmg is now fairly hard to bog down. The issue was that the belt had stretched slowly over the five years and I was getting increasing belt slippage. Basically I build faster, more powerful and vairable speed grinder to fix a problem that really only needed the ten second fix of sliding the motor back a half inch. The 2hp kmg with step pulleys was all I ever needed. Oh Well
