Every blade that I've forged out of O-1 has survived, even with judging the temperature by the heat color. I've used mineral oil for the quench, and have not gotten a crack.
There are days when I wonder if all of this isn't some kind of metallurgical voodoo.
You're on the right track. You got color and temp and quench.
You've left out the most important factor with O1, and that is TIME!
There's no voodoo involved.
Read Kevin's post.
From what I've gathered here, what is happening on your 10XX stuff is that you are getting them HARD! Perhaps, too hot and over stressing them, but now you see what you're up against when actually creating martensite!
It's just easier to create martensite with siompler steels than the complex O1 you mention.
The reason you're not having trouble with your O1 is that you're not getting full hard.
That stuff needs to soak about 20 minutes at a controlled 1500 degrees for full austenization of the steel. And THEN quenched in the right oil. If you're not doing that, you aren't bumping up against the "martensite wall"!
It's almost like saying that if you aren't getting in trouble, then you're not getting anything done.
See what I mean?
That's what Kevin is saying.
He'd rather KNOW that he stressed his steel to the point of cracking by creating full martensite than only make a little martensite, have no cracking "issues" and a knife that worked a little bit, and passed as a "success".
I know I'm saying the same thing, but in a different way.
There is NO VOODOO involved.
You just need to treat each steel the way the industry designed it.
