- Aug 19, 2007
It all comes down to personal preference. I've learned a lot experimenting with different designs.
I have a hard time cutting with a perfectly flat blade. The blade must be perfectly flat against the board to finish the cut (especially with tough-skinned foods); either that, or you must slide the point though, with just the point contacting the board. On short blades, it's pretty easy to just keep the point down and slice, but it gets awkward as the blade gets longer. With this technique, the point wears quickly, but the rest of the blade stays very sharp.
The traditional chef knife has a belly and the blade is either rocked or sliced with. The belly of the blade is in contact with the board most of the time and sees the most wear. This wear is more distributed and, (for me), easier to sharpen out. Too much of a belly makes it awkward to put the tip in contact with the board.
There are also concerns not relating to cutting, such as scooping up food (as DWK mentioned).
I recommend sitting down with some paper and trying to design the perfect kitchen knife for you. You could even make some wooden mock-ups. It is an interesting mental exercise that forces you to analyze how you use a knife. I certainly didn't get it right on my first try, (the wharncliffe pictured earlier), but I learned a lot.
Phillip
Great advice. I just showed your Blackwood chef's knife to She Who Must Be Obeyed and now I'm in trouble:foot:. She wants it.
